Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
Heater board is unable to stabalize temperature
I have a sr 400na in which the spa would get extremly hot. The control panel could not reset the high temperature of 255 degrees, with each attempt to reset at 104. I believe the heater control board is failed? I have the actual control board pn 42001-0096, but the manual says this model number should have a part number 42002-007S which one is correct?
  • 125 Answers
Here is the link again to the Sta-rite Heaters.
Posted on Feb 26, 2009
Control panel lights flicker, heater will not ignite
Possibly bad control board or a bad connection, need a little more info and I only have my phone to answer questions so I don't see the type of heater your posted under if you did.
Feb 28, 2016 | Hayward H400FDN Low NOx Natural Gas Pool...
I have a minimax ch 150 heater and the heater is running but the water coming out is not as hot as it used to be. Though the heater is extremely hot on the outside. Any tips?
Check your SENSOR. With the Minimax ch heater, you might be using an 'IntelliTouch' panel that controls your equipment. If you are, check the reading that the panel says the water temperature is and then check the temperature of the water 'coming out' (spa??) manually with a floating thermometer. When the heater cycles off, check the difference between the 2 numbers. Say the panel says 102 & the thermometer says 95?? - that is a faulty sensor, telling the heater that the water has reached 102, so it cycles off before ever getting hot. If you're not using the IntelliTouch, you will be checking the display panel on the actual heater itself & again the floating thermometer. Now... if the temperature is less than a 4 degree difference you can always calibrate/or have calibrated the heater.
Aug 03, 2010 | Pentair MINIMAX NT TSI IGNITER
So how do I fix this problem "sta rite 400na gives error code 05 after about 30 seconds?"
if it starts check your stack sensor its the one the exaust ----- And if it dont start change your ignition plug
Jun 19, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Mar 18, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
What does oh mean on hot tub a cal spa
'OH' means 'over-heat'.
Basically the high-limit temperature sensor has detected a temperature far in excess of what it should be.
Check the filter(s), water flow, pump etc....
Regards,
Ian.
http://hottub.synthasite.com
Jan 26, 2010 | Coleman (5040B750) Patio Heater
Panel reads HHO-----, no temperature display until activate jets, then shows a temperature drop sometimes down to 65 degrees ,then starts heating upwith jets going
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
Dec 24, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Dec 28, 2008 | Arctic Above Ground Rugged Mesh Winter...
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
473 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
