Question about Whirlpool GD2SHGX Refrigerator
Water is leaking from water dispenser
I have whirlpool refrig... the water is leaking
  • 700 Answers
Sound like the solinoids in the back oif your refrigerator may be leaking thru the valve causing the water the coutinue to come out and making a mess.
Posted on Mar 21, 2009
Leaking a lot from water filter, which is inside and on roof of refrig.
Has the filter ever been frozen? that can cause it to crack. If not, it is probably going to be the filter head that has failed seals... Whirlpool Refrigerator Water Filter Housing WPW10238156
Mar 17, 2016 | Whirlpool WRF989SDAM 29 cu. ft. French...
Leaking ice maker
I cannot provide information on the particular problem but I suggest you find the model and serial number of your refrigerator and search the Whirlpool website for any service bulletins or recalls. In the meantime keep the water turned off to the refrig. until a repair is identified.
Aug 19, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool refrigerator Model GI5SVAXVL01. (2 door upper- Freezer on bottom). SN K01668079 About once a week there is a puddle of water on the floor right front side of refrig. I cannot tell where...
After looking carefully at the exploded views of this refridgerator
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GI5SVAXVL01/1198/0161000?pathTaken=&prst=0&shdMod=GI5SVAXVL01
I believe your problem is caused by a leaking hose or fitting for the water dispenser
Pay close attention to items # 11 and 19 on the diagram labeled Refridgerator door parts
Try turning off the water supply to the dispenser and see if the problem is resoleved... if so you know thats where the problem is
Jan 21, 2011 | Whirlpool Refrigerators
In door water line plugged or froze up.
Whirlpool water lines do not plug or freeze . Replace the dual water inlet valve behind the refrig , where the wall water line connects to on the refrig .
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Whirlpool fridge freezer with ice dispenser
replace the water valve located where water line goes to refrig.
Jan 15, 2008 | Refrigerators
Whirlpool GD2SHGX Refrigerator Logo
213 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
