Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
F&P Intuitive WM. Needs Bearings and seals replaced
Our Fisher and Paykel Washing machine needs new bearings and seals.
Is this something that a handyman can acomplish and if so, how does one go about it.
Where can I get the parts in NZ.
  • 144 Answers
Hello you can get the parts from any New Zealand F & P service center( $50-80nz). You need a special F & P tool kit (you can buy for around $100nz from F & P also) to remove the seal and bearings and to insert the new. unless you know an appliance tech or have a service manual it could be a tricky one. cheers
Please Rate my Advice
thanks
Steve
Posted on Mar 25, 2009
Noisy spin [sounds like a train]
Bearings are probably failing. This needs servicing with parts, bearing and belts.
Nov 17, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Needs Service code 136
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. Nominal resistance should be around 32Ohms.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and basket by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Tertiary Source: Motor Control Module.
Action: If the primary and secondary checks pass inspection, then replace
the Motor Control Module.
Jul 16, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
My washing machine has been sounding very noisy in the spin cycle, and today it started beeping "asking for a service" code 131. It is approximately 11 years old not sure whether to bother with a service...
if your unit has a lot of use then the noise is proberly bearings r faulty.leaking is proberly due to main seal fault. ring service centre get a qoute for main seal and bearing replacement.also an electrical fault has happened proberly due to leak,so that could b added cost.good luck with it please reply if u need more help.
Mar 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GW708F Screaming like a jet engine on spin!
Hi there
Yea if the machine sounds like a train going through the middle of your house when its on spin it will most definately by your seals and bearings, an easy way to check is lean the machine back onto something and look underneath if the main seal is leaking and the bearings are run there will be rusty looking residue on the motor rotor(the round thing in the middle of the drum), seals and bearings are fairly expensive to replace About $350NZD if no shaft is needed and up to $500NZD if a replacement shaft is needed.
I hope this helps you out.
Nick
Aug 03, 2009 | Fisher and Paykel Fisher & Paykel Washer
I've got a fisher paykel gwl10 top load washing machine
Check the pipes leading to water pump for wetness also the door seal,If all pipes are dry and look ok then it could be due to the water seal and bearings braking down.
Jun 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Bearings
I can talk you througt this in live chat, but you'd need to get a F&P Bearing replacement toolkit and seals and bearings and a new agitator shaft. cheers
Jan 01, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
437 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
