Question about SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card Reader
When i connect the pen drive or card reader to usb port it is not decteting
  • 1 more comment
  • Anonymous Mar 07, 2009
    when i insert pen drive in sun solaris system its not detect
  • pwest14 Apr 14, 2009
    when i plug reader in to usb with micro sd in the reader its not detected
  • Jkwoner May 11, 2010
    do you have a memory drive plugged into the reader?
    You can't just plug in an empty pen drive or card reader..
    -sorry if i mis interpreted ur question
  • 3 Answers
Posted on Feb 22, 2009
My Genx pen drive is write protected
Usually on the "thumb" or "pen" drive there is a small switch that locks and unlocks the drive so you can protect data. If you need further assistance let me know.
Thank you,
Lee
Feb 01, 2011 | Dynex External USB 2.0 Multiformat Memory...
Its not even showing up on my computer that it is connected
Not to be a wise guy, but did you have the memory card in it when you connected up? If so, take it out and clean the contacts with a soft cloth and at least 90% alcohol. Also, look inside the reader to make sure none of the 4 pins are bent or broken. If all this fails, try it on another usb port. Sometimes they get reassigned by software or something, and won't detect certain devices on certain ports, for unknown (to me) reasons. If all this fails, try the card reader on another computer (maybe you should try this first). If everything fails, I would deduce the card reader is bad, and get another one. Good luck.
Apr 09, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
My pen drive of 4gb is not working when it is connected o my pc
may be your USB port is not working. try another port and one more thing may be you plugged the usb in that port and it shorts the usb and port too then might be your pen drive is not working
Mar 17, 2010 | Computers & Internet
How do i save my documents to ubs drive.
Please put ur memory card into card reader.
connect the card reader to the USB port of ur computer.
Now u can use ur memory card like Pen drive.
If the solution is working please vote for me....!!!!
Thanks
Curren009
Feb 19, 2010 | SanDisk 4GB microSDHC Memory Card
How do i use it?
If its a simple memory card reader, all you need to do is plug it into an available USB port then ensure your PC detects it. Also, make sure drive letters appear for each card slot.
Feb 14, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
When I connect the card reader to a school computer, one drive comes up but it will not read the card. This is an XP computer
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the card reader, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your memory card, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your memory card to be detected automatically.
Hope this helps you out.
Nov 24, 2009 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
When I connect my Pen drive to my laptop it asks for driver.
you turn the usb ports on thru the bios setup menu that you can enter as you boot up... actually tho you shouldn't have to do anything.... just plug in the usb device and your operating system should detect it for you.
Apr 11, 2009 | Computers & Internet
Usb pen drive does not fnction
Try connecting the pen driver to another usb or another pc to make sure that it's a problem of the usb port of the pc.
May 08, 2008 | Computers & Internet
Unrecognised external drive
Hello Sir,
Here are a few things to try. If you have access to a secondary PC or laptop, try connecting your drive to it using a different USB cable. Also try unplugging your drive from the power outlet for a few seconds and then connecting it again. If it?s still not being recognized, Maxtor has a free utility called PowerMax (available at www.maxtor.com) that lets you run various tests on your drive till it identifies the problem.
Plus another thing to look at is if whether or not plug and play is disabled in the system Bio's. Course the easiest way to see if that is the case is to plug something else like a pen drive into the USB port and see if it is even working. It may also be that the USB port is not working or is disabled, or better yet your system has only a USB 1.0 port. In which the pen drive may work but it is not enough for the Ext. Hard Drive which requires USB 2.0.
But the remedy is to first try the drivers and software, then check to see in your hardware manager what USB you have, then if plug and play is enabled in the BIO's as well as what the USB setting is in the Bio's, and last but not least add a USB 2.0 PCI expansion card and try that.
Plz forget to comment....
Cherrs!!!!
Jan 08, 2008 | Computers & Internet
SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card Reader Logo
786 people viewed this question
Top SanDisk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
CiNi
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
