Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
I NEED TO KNOW WHERE TO HOOK UP THE WIRES TO A RAYPAK GEMINI 3 HEATER COMING FROM THE SPA......THANKS FOR YOUR TIME....DENNIS....
  • 125 Answers
Here is the Mfg Link so you can trouble shoot your heater.
RayPak
Posted on Feb 26, 2009
Raypak pool heater shows 'sensor failure' and also 'sensor open' - what does this require/ thanks
I would check the sensor wiring on side of unit where the inlet and return manifold is - chances are little critters chewed the wires to the sensors. may need to replace the wires if they are too mangled, or can try to splice
Jul 31, 2017 | Raypak Pool & Spa
Hello every one ive just purchased a Raypak gemini 3 Heater for my spa im hopeing someone can supply me with a plumbing diagram ive got a basic idea on how it needs to be plumbed but i would like some...
The pipes go from the pump to the filter to the heater. The intake for the heater is on the left side, the heater out put is on the right side.
Aug 05, 2013 | Pool & Spa
Heater on and off all the time
check gas pressure if ok check safety circuit and wires to pressure switch and gas valve see if manual bypass is ok maybe spring bad and heater overheating
May 09, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Raypak Millivolt propane pool/spa heater that I would like to connect to my Jandy Aqualink. The Raypak millivolt heater only has a thermostat, pressure switch, flame roll-out switch, and high...
All you have to do is put your Aqualink in series with the heater's safety loop. Sometimes there is a terminal block, but regardless if you can find the pressure switch, cut one of the wires and connect the wires from the Aqualink to each side. (There are two ports on the top of the Aqualink power center board designated for this)
At that point the AL is in control of the heater. Make sure that the heater is powered up, turned on, and your thermostat is set to max.The AL will turn the heater on and off following your programmed temperature setting.
Feb 06, 2013 | Raypak Pool & Spa
Need a manual for a raypak 346 optimum pool heater
Not familiar with "Optimum" by Raypak.
346 is probably your output BTU/Size in 100,000's, so 346,000 btu
What is model number of your heater? Metallic label on inside of the heater behind the front cover/door.
Some Common heater models current & obsolete are as follows:Gemini, Versa, RP2100, Delta, xfyre
Dec 29, 2012 | Raypak Free Hydraulic Lift Gate Delivery -...
How can i get a power vent for my raypak rp2100 pool heater
yes if no area on board for fan hook fan if series with firemans switch when fan on heater will work or a air switch
Oct 29, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My Versa Raypak heater will not light and I am not mechanical minded enough to make repairs. Is their a Raypak authorized repair service in Lancaster, CA?
A V HAWAIIAN POOLS INC
4085 WEST AVENUE L
LANCASTER, CA 93534
(661) 943-0557
redletter-b.png 31 miles
Directions DENNIS RETTELA'S SWIMMING
11463 ORCAS AVENUE
LAKEVIEW TERRACE, CA 91342
(818) 896-4690
redletter-c.png 44 miles
Directions VALLEY HOT WATER
4212 E LOS ANGELES AVE
SIMI VALLEY, CA 93063
(805) 526-5594
Aug 04, 2010 | Raypak Versa 130,000 Btu Above Ground...
Raypak els1102 pool heater problem
Hard to saw from here, but I assume you have a book on this, find your hi limit switch, it will have a reset button on it. It will be behind a rubber plug on the housing but is hard to reset sometimes. If you pull the cover it is easy to reset and once you see it you will be able to do this with the cover on.
If not this some damage may have been done to the coil in the contactor, you should be able to see it pull in or at least hear it klunk when the heater kicks on.You probally won't be able to feel heat when it runs as it is designed to protect you from scalding when it runs but you should feel a slight difference in the temp of the water coming from the returns in the spa. good luck and let me know how it works out.
Nov 01, 2009 | Raypak Electric Heater 11 Kw
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
262 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
