Question about Numark Pro TT-2 Turntable
Numark TT1 need to be manually started by moving platter
TT1's will not start rotation on their own. The platter needs to be rotated and then the motor starts driving the platter. Also doesnt stop rotation when the button is pressed.
  • DJ CRIMSON Apr 09, 2009
    I HAVE THE SAME PROBLEM BUT WITH TT200 I HATE IT AND BECAUSE OF THIS I FIND IT ALMOST IMPOSSIBLE TO DOUBLE DROP ANYTHING IF I DONT FIND OUT SOON I MAY HAVE TGO SELL MY DEX BUT I WILL KEEP LOOKING 4 SOLUTIONS IF I FIND ANY I WILL UPDATE THIS POST ALTERNATIVLY IF YOU FIND OUT B4 ME COULD YOU SEND ME A QUICK E-MAIL ON WALKER.LEE88@YAHOO.CO.UK CHEERS
  • 69 Answers
That'll be a blown component of some sort on your main board i think mate,youll wanna get some one handy wiyh a multi meter.gd luck
Posted on Aug 08, 2009
Numark ttx/ttx1 pitch fader wonky
Try spraying the slider with Servisol Video 40.
Mar 15, 2013 | Numark TTX1 Turntable
Platter vibrates; doesn't rotate smoothly
Do one thing Remove the palter and put one drop of lubricating oil in the center shaft. Also put one drop in the motor shaft. Be carefull do not drope the oil in motor pulley. If so clean the pulley with a cloth. Because it will cause slipping the belton the pulley.Then put the plater back. Rotate the plater with arms for some time. Then check.
Ajin
May 07, 2012 | Numark ttUSB Turntable
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
Washing machine syndrome. can this be fixed?
It means you are having a servo problem. The least you can do is remove the top platter and clean the servo sensor ( a small head which faces the inside of the platter. Its a magnetic head which picks up feedback pulses from the rotating platter and locks the speed of the motor electronically. You will need professional help to fix this problem.
Mar 11, 2011 | Numark TTX1 Turntable
I cannot manually move forearm it keeps going back to resting place
Try adjusting the weight on the back of the tonearm. If it's too light the tonearm will just glide back to it's starting point.
Jan 13, 2010 | ION Audio iTTUSB Turntable
Numark x2 motor problem
I would like to know if it possible to use my Numark DXM09 mixer ... with two Numark ICDX players and use Numark Cue software
Oct 14, 2009 | Numark x2 Hybrid Turntable
Start/stop button doesn't move platter
nakered switch then needs replacing
Aug 07, 2009 | Numark Pro TT-2 Turntable
JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Apr 07, 2009 | JVC AL A158BK Turntable
Belt has come off my numakr tt1610's
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Apr 02, 2009 | Numark TT1610 Turntable
Ttx 1 numark
hiya fixya...well i just opted,,,to take the thing to the repairs.the conclution is that the"platter rotation sensor " had burned out.sent the deck off today.will let you know the outcome,to maybe pass on this info to other ttx 1 users for near future....thanks for your responce.quote 35 quid just to confirm problem...but deducted from final bill of??????.westend dj staff are very helpful indeed where i puchased them from in the begining.
Mar 31, 2008 | Numark TTX1 Turntable
Numark Pro TT-2 Turntable Logo
379 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
