Question about Casio Exilim EX-S880 Digital Camera
Casio exilim ex-s880 wont charge battery has been replaced and when on the charging dock charging light just blinks
  • Anonymous Mar 12, 2009
    Having the same problem. I wonder if replacing the battery will help...
  • 7 Answers
I had the same problem. Here's what I found that worked for me. I had to do this about 7 times but others that I read had to do it about 20 times but worked for them as well. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
5 Suggested Answers
  • 8 Answers
SOURCE: Casio Exilim EX-S880 I put
if you try pushing the battery in further it might turn on, if that doesn't work just get a new battery, but make sure to take it out when you aren't using it or this will happen again.
Posted on Feb 13, 2009
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont charge.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
ylu1 writes:
what i did was...
hope this helps.
  • 19 Answers
SOURCE: Casion Exilim EX-S880 Charging Error
Clean your connecting areas with alcohol . If that dont work . It could be a bad battery
Posted on Aug 18, 2009
Is there a way i can restart my ex-s880 exilim camera so it will turn on?
Are you having problems getting it to charge if when you put it on the charger the red light blinks then try this : I tired it and it worked... If not you may needa new batt. Just plug the power cord into the craddle, not the usb. Then put the camera on the craddle and let the red light come on, but not long engough to let it flash. Repeat this like 10 - 12 times jsut putting it on for a couple seconds. This will boast the batt engough to let the camera software know that once you put it on the dock that is is suppost to charge
Nov 01, 2009 | Casio Exilim EX-S880 Digital Camera
Battery in cradle don't charge
Two reasons. Either the battery is dead or the cradel's charging circuit is faulty. But the red light shows that the cradle is fine. SO, the axe falls on the battery.
Sep 19, 2009 | Casio Exilim EX-S880 Digital Camera
Aug 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
ylu1 writes:
what i did was...
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
My Casio Exilim EX-S880 wont charge. when i put on the charger the red light blinks but it is not charging.
ylu1 writes:
what i did was...
hope this helps.
Jul 16, 2009 | Casio Exilim EX-S880 Digital Camera
My Casio Exilim ex s880 wont turn on i have tried everything
you need anew battery...try ebay or battery planet.com for a replacement.
Mar 30, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 will not turn on
The problem is the spring terminals inside the camera are not making good contact with the battery. I had to use a screw driver and gently push them to the left to make better contact with the battery terminals. There are three connections. I stress that you be gentle. This not the long term fix but you will be able to take pictures in the short term.
Feb 25, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 I put my camera on the charging dock and the orange light comes on. After about 15 seconds it starts flashing. I can't turn my camera on at all. The only way I do is to view them on...
Jan 29, 2009 | Casio Exilim EX-S880 Digital Camera
Casio ex-s880 model
It could be the battery isn't taking a charge. Since your purchased the camera last February you could be still covered under warranty. I would check with Casio.com. I found this link on their website:
http://www.casio.com/support/authorizedservice/
Jun 22, 2008 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
322 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
