My Lenovo u410 shuts down unexpectedly a few times a day. Sometimes I am watching a video when it shuts down, but it has also happen when i was not doing anything I just turned it on and I was about to use it when it just powered down by itself. I just bought this a week ago and I haven't done much to it so it can't be a virus. Any solution or suggestions?
SOURCE: my lenovo G460 shuts down unexpectedly
http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5 avg free 2012 http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials If you believe a virus may be the cause of your laptop's shutdown problem, run a virus scan on the system to find out if any exist. if your laptop keeps shutting off When you troubleshoot the laptop, remember that it is also possible for a combination of causes to be at work. Excessive Heat Keep Cool All newer laptops have built-in heat sensors that shut the computer off when it exceeds a pre-set temperature threshold. Install and run a temperature monitoring utility to determine whether the laptop is overheating. might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Hardware Issues If you replaced or installed new hardware in your laptop, use the device management utility to review if there are any resource conflict or failure reports. You can also remove unnecessary hardware and run the laptop to see if the problem persists. If it doesn't, reinstall each hardware component and re-test until the laptop fails. Operating System Issues The operating system start-up controls can affect how the laptop performs. Follow the operating system developer's instructions for entering the start-up program, and confirm that the settings are what your laptop requires. Power Supply If your laptop is not getting the correct power it requires, it will shut down completely. Test the current of any outlets you use with your computer, employ a surge protector to ensure steady current, and confirm that the power supply itself is not defective. Battery Failing batteries can produce unexpected laptop shutdowns. Use a battery monitoring utility to determine whether or not the battery is healthy and replace it if it isn't. Malware Unfortunately, rootkits and viruses can cause your laptop to shut down without warning. You will probably have to take the hard drive out of the laptop to be able to scan it fully and remove any malware that is installed, or the laptop will shut down before the scan and repair can finish. http://www.malwarebytes.org/mbam.php Malwarebytes is as the name says, a Malware Remover! Download the Free Version from the link above. Download, install, update and scan once a fortnight. http://www.spybot.info/en/index.html Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program. Download, install and update it. Then SCAN with it. Update it, and scan your System once a fortnight. Hope this helps
If your laptop suddenly shuts itself off for no apparent reason, there are several factors that can contribute to the problem.
