ATI 3D Charger  PCI Graphic Card
Problem for ATI 3D Charger (4 MB) PCI Graphic Card
Digital 164SX & ATI 3D Charger 4MB PCI - No video???
By Janice - usenet poster
I have recently purchased a Digital 164SX motherboard & 21164 533mhz
processor, however I am having trouble getting the system up and running.
When I power the system on, there are no beeps, and the monitor remains in
suspend mode. I tested to make sure the board had power - I removed the
memory and received the 5 beeps that indicate 'no memory found' I have
double checked the configuration switches and everything looks OK.
Has anyone used an ATI video card on one of these boards? I am trying to
use a 3D Charger (Rage IIc chipset). The Alpha-OEM hardware compatibility
list shows only the Matrox Millenium II, #9 Motion 331, and a Symmetric card
as being tested. What other cards are known to work?
I was also wondering if it could be a memory problem - I am using 4x64mb
Toshiba 100mhz 8Mx64 dimms. Should these work with this board??
Any help is greatly appreciated.
Thanks.
Kevin..
Best Solution
posted on Aug 02, 2007
Helpful)
Melissa
Rank: Apprentice
Rating: 0%, 0 votes
Thanks Jurgen, I went out and picked up a S3 Virge/DX today, and it worked
like a charm. I was able to boot with all 4 DIMMs although I haven't had
time to play with it to see if I have the same startup problem...
Kevin.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
I have the exact same board but use a S3 Virge/DX PCI card with 4 MB as
my videocard. As memory I use 2 standard 64MB 100MHz SDRAM DIMMs. They work
but there is something odd. When the machine does a cold start (and is being
shutdown for a while) it always comes up. But when I shutdown and power off the
system and bring it up again it does not always work. My guess is the memory
(it's non ECC). Maybe you can try to boot with just two DIMMs?
Greetings,
Jurgen
Was this helpful?
Yes
No
Popular Solutions for ATI 3D Charger PCI Graphic
Questions and Unsolved Problems for ATI 3D Charger PCI Graphic
Do you recommend ATI 3D Charger (4 MB) PCI Graphic Card?
Answer
Answer
How do i program remote to turn on and off tv
Answer
9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS... (More)
Answer
Apollo A9200SE-128MB+TV+DVI/A: VGA connected. At power up, good picture for 10 sec, then PC shuts... (More)
Answer
tried installing my mad dog fx5200 but wont show my desktop options
Answer
what can i upgrade to from an ATI radeon x300/x550/x1550 graphics card with 256mb. And is it easy to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Graphics Cards Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
