Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Red light stays on continually. - Sharper Image Ionic Breeze 3.0 Air Purifier
  • Dennis Beckett
    Dennis Beckett Feb 22, 2009
    I researched this issue. I found zero solutions, so it is an inevitable problem that cannot be corrected. I am throwing mine away.
  • dbabcock Mar 27, 2009
    Red light stays on.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Posted on Mar 14, 2009
Why does my Kenmore intuition vacuum 31810 Red light stay on ?
Here's a couple options
http://www.ehow.com/way_5513470_kenmore-vacuum-troubleshooting.html
http://www.shopyourway.com/questions/1128413
Jul 28, 2014 | Kenmore Intuition 31810 Upright Bagged...
SHARPER IMAGE IONIC BREEZE QUADRA RED LIGHT ON
I had one that had the "needs cleaning" light was on. After cleaning, the light stayed on. I checked around at the time and learned it couldn't be fixed, and it was out of warrantee. I believe that's why they stopped making them. Mine was just thrown away.
Apr 02, 2012 | Sharper Image Air Purifiers
Have a red light on in front - looks like something needs serviced. I rinsed the filters that pull out and light stays on. Might be a filter further in the unit or something might need to be reset??? ...
To the left of the little red light is the reset button. It's disguised as another light that isn't on. :) Press and hold it for about 10 seconds and the red light will turn off.
Mar 03, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Ionizeair "check" red light is still on after cleaning
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Aug 19, 2009 | P3 International IonizAir P4620 Air...
The red cleaning light is staying on after I have cleaned it several times
I have had to hit the power button several times in a row to get the red cleaning light off till the other light went blue. Thats what I did, Did you just clean the blades? there is another part that cleans the wires too, Its like a plunger.
Dec 07, 2008 | Ionic Pro CA200 Air Purifier
Red light on holmes 422 hepa filter air purifier.
What is the complete model number of the unit?
Two types of a 422 popped up on their website.
Oct 27, 2008 | Air Purifiers
Sharper Image MIDI S1853
Could be a blade replacement needed but Sharper Image recalled the product.  Since it was proven in court that it wasn't effectively cleaning the air by Consumer Reports as well as EPA data.  As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
Sep 17, 2008 | Sharper Image Professional Plus Ionic...
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
1,000 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
