HP iPAQ 510 Voice Messenger Smartphone Logo
A
Anonymous Posted on Mar 07, 2013
How to change hp ipaq 500 startup.wav - HP iPAQ 510 Voice Messenger Smartphone
2 Related Answers
A
Anonymous
  • Posted on Oct 24, 2008
SOURCE: btavui - Error 0x37 opening
Solution (on my hx2490 wm5): go into file explorer, and enable view all file in the menu tab, then go into windows directory and find btcoreif file, rename it or delete it, then reboot your pda. and voila! problem solved, sound works fine
Anonymous
  • Posted on Aug 26, 2009
SOURCE: Won't get through blue HP startup screen.
try taking battery out for 6hours then reinstall and hard rest.
this works on mine. bob
2helpful
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
My HP ipaq rx5700 stucked on boot, need to reboot and wok properly
IPAQ EXPERT HERE
Welcome to fixya
I have a solution for this
Content
Your pre-solution is located above. More information is available in the comments
We will need to check the boot ini file first. Then we would need to check the configuration for startup errors.
My name is Bruce
1helpful
Btavui - Error 0x37 opening WAV driver What does this mean? How can I get sound back on my hp ipaq hx2490?
1helpful
2answers
IPAQ 6965 problem
Go to \Windows\StartUp and delete the offensive program.
My hp ipaq voice messenger 500 series wants to format my storage card on start up
I have the same problem with my hp ipaq voice messenger 500 series wants to format my storage card on start up.
2answers
Ringtone change
The ipaq is not playing large files. It only makes a small beep sound if the wav file is big. I am using a wav file of less than 800 k and it works.
Some programs not running
Take a look at this similar post - http://www.fixya.com/problems-solutions/t115221,p477250/HP-iPAQ-hx4700-Pocket-PC.aspx Let us know if you resolved your problem Good luck
How to convert audio in notes to wav?
This was a fun project. Here's how I did it. You'll need to download a freeware audio editor named Audacity. I did this on a Mac, but it's cross-platform, and I'm assuming the menus are the same for Windows. http://audacity.sourceforge.net/ Then. (1) Copy .pwi (Note) file to PC (2) Open Audacity (3) Get the Note audio into Audacity by: Project menu Import as raw data (4) Select all of the audio by clicking below its file name at left of the graphic of the file (5) Click on dropdown menu (arrow next to file name) Set Rate to 11025 Hz (6) Convert to WAV by: File menu Export as wav
Top HP Cell Phones Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
