Question about Gigabyte Computers & Internet
Booting problem When i power on my pc in the morning it is not booting. if i remove the cmos battery and fix it again and it is bootinf fine. but i have also changed the cmos battery but the same problem is persisting to me. can u help us to me to solve this problem.
  • 129 Answers
I think the CMOS battery is not connected properly when it is taken off and replaced. Check if the connector on the top is in contact with the battery correctly.
Posted on Feb 22, 2009
Pc froze, I unplugged it, now it has power but won't boot
Unplugg from power.
Remove the hard disk and re-fix it again.
Do the same with the CMOS battery.
Connect power and start the PC.
Hope this helps.Thanks!
Oct 20, 2011 | ASUS P4SDX Motherboard
HP Compaq NC6000\r\nWhen I press the power button it seems to start but the only thing I see is numbers going by rapidly in the form of kbytes (524288 KB ok) then it reads 162-system Options not set. Then...
Hi promano67
When you "start" the computer, and the {"Screen"} displays a "Error Message."[CMOS] "error checksum!"
Settings: "Default" loaded.A "checksum error" shows that:
The ("Boot-up Settings "have been changed?"), ie. "Booting OS."
*Boot File 'missing'.
"This can 'occur' if the computer was "shut-down unexpectedly."
Force Shut-down : Power lost; due to 'low battery...'
A ("Power Surge") can cause this 'problem' also.
"What 'happens is that the [CMOS] settings are lost!".
"To fix the problem!"
Do the following:
  • "Restart / Boot the computer.
  • Next, verify if the 'error message' displays?
  • If you are still getting the message?
  • "You will have to "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}._953.jpg *Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
  • Replace the "CMOS battery."
  • Next, "Only plug the Power Adapter into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" _951.jpg
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 13, 2011 | HP Compaq nc6000 Notebook
How can remove the cmos password
hi, if you know how to open a computer or laptop, just remove the cmos battery, it is a round shape silver battery just like the battery for wrist watch but its like 3 or 4 times bigger than the regular wrist watch battery,...just remove the cmos battery then boot up your computer then, after booting up, shutdown your computer then put back again the cmos battery, then boot up again your computer then you can go directly on your cmos, it will not prompt you for any password
regards
Dec 04, 2010 | Computers & Internet
Computer powers up but no video even tried with another graphics card
SUGGESTIONS, CHANGE CABLE AND OR DISPLAY. ONLY SUGGESTIONS I HAVE
Feb 26, 2010 | EliteGroup K7VMA Motherboard
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
Aug 29, 2009 | Dell Studio 15 Laptop
My computer won't boot! It keeps restarting before Windows screen.
Make sure the cmos jumper is plugged in. Turn off your pc, unplug the power source. Remove the cmos battery for 30 seconds then put it back. Reboot your pc. Give us feedback! Hope that helps :-)
Jul 25, 2008 | Abit IC7-G Motherboard
Startup password forgotten
Did you remove all other power supplies from the computer, like the battery and AC adaptor. try this again, only leave the CMOS Battery out for 2-3 Minutes, with no other power supplies attached.
Jan 11, 2008 | HP Compaq Evo Notebook N600c
Open Questions:
Computers & Internet Logo
75 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
