Question about HP LaserJet 1200n Printer
Laserjet 1200 prints off the edge off the page - please help
My Laserjet 1200 prints off the edge off the page. I havechecked margins and a bunch of other things and nothing seems to work. any suggestions would be appreciated.
thanks
  • 42 Answers
Do you have the correct paper setting, drivers, etc ...
does it do that in all programs or gist in one or eg. gist for text?
on all paper sizes?
what if you load the max paper size sheets? it shouldn't be able to do that then.
what ratio do you have in the settings? make sure it's 100%
what if you make the print object smaller?
Posted on Feb 22, 2009
Booklet margins being cropped
You don't need the original HP install disc. Go to the H Support site and download and install the newest one listed for your operating system. Turn the printer off and unplug it, wait 10 secs and plug it back in after installing the latest driver and software. Should work fine for you.
Oct 13, 2014 | HP LaserJet 1200n Printer
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
How do I change the left margin on the printer? I have an internet app that sends the document and I'm unable to change the margins in the internet app.
That's why they are called margins.
You can't print to the edge of the page. The printer physically can't.
Have you tried printing landscape? The other thing to do is set "scaling". That will cause the printer to shrink the page slightly to fit your paper size.
Dec 21, 2010 | HP LaserJet 3050 All-In-One Printer
Prints out of alignment on excel spreadsheets
go to print preview, then to the margins button at the top and click it, margins will appear on the page, adjust your margins to the edges of the page, if the spreadsheet is supposed to be on one page and doesnt fit, go to page setup and shrink the size of the document (will be percentage), either way--once you have moved your margins out to the edges, you can then move them back in a little at a time if you need to in order to center your document on the page. Hope this helped.
May 10, 2010 | HP LaserJet 1320 Printer
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't print proper legal size documents
please you aply the comand control p and you go the property select
and ok. you so the paper select and ok and you so the paper size
in select legal is ok and ok
and aply print legal size print ok
Sep 15, 2009 | HP LaserJet 1018 Printer
Setting margins on printer
Well, by now you may have found the solution, however, make sure that in MS WORD under File > Page Setup > A4 is selected, and if you still this prompt (error), just click on OK and proceed with printing.
The Laserjet Printers are capable to print upto 5mms from the edge of the border.
Regards,
Nikhil
Mar 17, 2009 | HP LaserJet 4250n Printer
How do i print edge to edge using the G85 Office Jet all in one?
The G85 does not support edge to edge printing, it requires a top margin of 0.08:, a bottom margin of 0.46" and side margins of 0.25".
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Hp laserjet 1200
It may be that she needs more memory. It has 8mb standard, and you can add 8mb more. Make sure the fonts are not too complex or that the documents aren't graphic intensive.
Jul 29, 2008 | HP LaserJet 1200 Printer
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 1200n Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
