SOURCE: danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
SOURCE: Danby DWM99W doesn't agitate properly
Under the agitator, there is a plastic wheel with groove that goes on the metal shaft that is shaking the agitator to wash ur clother. On my machine, the plastic grooves are not there anymore, probably the effect of the cheap plastic rubbing on metal and that is why the agitator is not turning. Porely designed or maybe good design to make you spen money on fixing it. Just change the plastic wheel with a new one and it will start washing again. Good luck.
SOURCE: Danby DWM99W Top Load Washer - water over flows
Two things to check. One ,when water is coming into tub, switch off at the plug and note if water stops or not.If it stops, then the solenoid is good. Remove the plastic pipe off the pressure switch and blow into the pipe. It must not be blocked. Clear if it is so. Check for any cracks:holes or breaks on the tube. Replace tube back onto pressure switch and remove opposite end. Blow softly and listen for a click. if so pressure switch is good. Replace tube and retry.
SOURCE: water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
SOURCE: I need belt for Danby
You need to search appliance repair and find a local appliance repair company near you. Tell them the model number and they can look the part up for you and order it if they dont have it in stock. Then you can pick it up directly from them.
If your washing machine is leaking,
don't rush out to buy a new one just yet. Sometimes simple repairs to
the machine can fix the leaks saving you hundreds of dollars and days of
shopping for and installing a new one. Luckily, you don't have to be a
master electrician to do repairs. These steps will walk you through the
basics of fixing a washing machine.
Bellow are Instructions on how to solve the problem of leaking washing machine
Most likely the tubes bring water to your machine have disengaged. Find out where they are and refit securely.
