Question about Canon Speedlite 430EX TTL Flash
Canon 430EX flash will not flash in slave mode.
I want to use the canon 430EX flash as a slave driven by the normal internally build flash from my canon rebel camera. Can't seel to make the 430EX flash when I have it in slave mode when it is not attached to the camera. I want to have it a few feet away on a 6 foot stand adding light from a different direction.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
Posted on Apr 15, 2009
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
Yes it is. The system is simply measuring the flash to meter the exposure.
Dec 29, 2013 | Canon Speedlite 430EX TTL Flash
My canon speedlite 430ex does not charge up, batteries are new and rear screen works/lights up any ideas?
Sounds like an internal wiring circuit problem. It's strange that the screen lights up but the flash doesn't charge. You should probably get it checked by Canon.
Feb 11, 2013 | Canon Speedlite 430EX TTL Flash
Only get one flash when using slave
Yeah you should go into the menu on your camera and see if there is anything you need to change!!
Apr 02, 2010 | Canon Speedlite 430EX TTL Flash
Can the Canon speedlite 430EX be the slave to the 550EX speedlite
Most any slave light will work I use a old vivitar flash with a slave module in the cord to camera outlet woks gook for a fill light. helix camera .com ritz camera. or ebay don't digital flashes a little different than strobes i played with the settings until i got the desired lightng I wanted., if your camera has a hot shoe you can get a slave to fire an external flash with it.hope i helped
Dec 27, 2008 | Canon Digital Rebel / EOS-300D Digital...
The normal flash will not work
The camera in P mode does not allow the pop-up flash to work until you turn it on. Make sure the camera is in green box mode and if the flash does not work then the camera will have to be sent to canon for service.
Dec 16, 2008 | Canon Speedlite 430EX TTL Flash
430EX
your flash has a diffusion panel in front, make sure its in all the way
good day
yitzy
Oct 19, 2008 | Canon Speedlite 430EX TTL Flash
Slave Flash
I'm guessing you're talking about a wireless connection...
Unfortunately, the 430EX can only act as a slave. You'll need one of the following to act as a master control unit: 550EX, 580EX, 508EX II or the ST-E2 transmitter :-(
Matt
Feb 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 430EX TTL Flash Logo
1,828 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
