Question about Toshiba Satellite A300-0CF035 Notebook
Toshiba A300 not booting.
Screen is blank when the power button is pressed, disk drawer makes small noise and nothing else happens.
Then the power light stays on but there are no harddrive noises or anything else happening.
    Genius:
  • 2,785 Answers
Plz take out the battery and try if the problem is not solved then try by resiting the ram. if you are not familiar with the computer terms and parts you plz ask some professional to help you from your area
Posted on Feb 22, 2009
Toshiba Tecra M5 Boot Problems
man you push alt+ Ctrl +p so you can get it the Bios specially where has been saw it the flash cursor you will see now BIOS normally
Jun 30, 2012 | Toshiba Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to www.computers.toshiba-europe.com and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
I have a Toshiba satellite pro A300 which when it is powered up shows the 1st screen with options for setup etc using F2 and F12. The laptop responds to neither and goes to blank black screen with a white...
Hello,this is a common problem that is caused regularly from a virus or a software/driver that you have recently added and caused this.The first you must do is to try to boot from safe mode(pressing F5,F8) while you booting and enter safe mode and remove anything you installed recently.Also you can try to select Last Know Good Configuration.If non of this helped you must reinstall or repair the operating system.Am waiting for your reply.Good luck
Feb 04, 2010 | Toshiba Satellite A300-0CF035 Notebook
My a300 canot get to the advanced boot screen pressing f8, it just asks for a bootable disk. after the toshiba screen it says that there is no bootable device. i want to just reset my computer to the...
Your OS is not booting. There may be few reasons.
1) Your hard disk is damaged and your BIOS does not recognise your HDD. Goto BIOS setup and see whether your HDD is shown. If it does not appear there, you may have to replace the Hard Disk.
2) Your HDD is recognised by the BIOS but Master Boot Record (MBR) is missing or damaged. Try booting from an XP CD. See whether Windows Setup detects your HDD. If the setup says there is an existing installation, try repairing it. After repairing, reboot and see whether you can use the computer. Otherwise make a new installation.
Aug 12, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba won't boot
 You can boot from XP cd.
When prompted..press [R] this will launch recovery console.
Choose your windows installation (typically by pressing [1] press return..
When prompted for password type chkdsk /r
Press return..Windows will fix errors..type Exit and press return..
Let me know if that helps.
Jan 05, 2009 | Toshiba Tecra A8-S8314 Notebook
Blank screen
This might me cause of by two problems you need to check:
1 If you have genuine OS,and not expired.
2 your OS is corrupt, you need to repair (with OS disk) or reformat.
another secondary cause is due to malware or other virus infection which results in not displaying screen after bootup.
Try running in safe mode and run antivirus. or boot from OS disk to repair your windows.
Oct 18, 2008 | Toshiba Satellite A105 Notebook
Toshiba 32A32 won't turn on
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Feb 27, 2008 | Toshiba 32A32 32" TV
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
DISC WILL NOT EJECT
Don't know if this will work for you, but I unplugged the player then plugged it back in again whlie holding down the power button. The player did not power up until I released the power button and pressed it again. That did it.
Dec 26, 2007 | Panasonic DMR-EH50 DVD Recorder
Toshiba Satellite A300-0CF035 Notebook Logo
421 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
