Question about Kenmore 23012 Top Load Washer
Spins slow or not at all, in the spin cycle.
Runs fine, but it spins slow or not at all in the spin cycle. Agitates fine. I can hear the motor going when it is in the spin cycle.
Model # 110.23012102
  • Kenmore Master
  • 3,361 Answers
Remove the water pump and check for a blockage in the pump.
If no pump problem replace the brake and the drive coupling.
Posted on Feb 22, 2009
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
I have The same problem OPEN Lid and works fine
When you lift the lid, did the motor stop? Do you know if it agitates? If the motor runs and there is no agitaion or spin, check the coupler connecting the motor and transmission. If it agitates and does not spin, it could be a basket drive assembly. The lid switch can also affext the spin cycle. Many reasons why it won't spin. These are just ideas to look into.
Vic
Jul 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore Washing stops at spin cycle.
It sounds like your lidswitch. If it spins after you open and shut the lid, you must be jarring the lidswitch. This is a safety so kids can't open the machine while it is spinning fast. Just replace the lidswitch.
Jan 19, 2009 | Admiral AW22 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Maytag Performa Washer spins fine but stops instantly
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Frigidaire washer topload, Agitates but the tub spins
yes the problem parts of the transmission if your going to keep it have new transmission installed
Jan 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Kenmore 23012 Top Load Washer Logo
367 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
