Question about Maytag MZD2669KE Side by Side Refrigerator
MAYTAG FRIDGE WILL RUN FOR A MONTH THEN JUST SHUT DOWN UNTILL YOU TURN IT OFF FOR A COUPLE OF HOURS
  • yraykh Mar 31, 2009
    Maytag work for a month after full cleaning then going in sleep mod.
  • 700 Answers
It sound like to me that it's freezing up. make sure that theres plenty of room aroound the food in the freezer for air flow and also is the gasket ariung the freezer in good condition? also is it clean and making good contact with the unit?
Posted on Feb 22, 2009
My fridge is making a very loud noise coming from the rear and bottom of box.we have already shut it off for four hours it stopped making noise for a couple of weeks,but now started again,we shut it down...
THERE IS A FAN IN THE BACK OF THE FRIDGE , INSULATION GETS LOSE AND HITS THE FAN. REMOVE THE LOSE ISOLATION OR WHATEVER IS HITTING THE FAN.. I THINK THIS IS THE PROBLEM..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | LG Refrigerators
Fridge door was left opened and now the fridge wont work but freezer working fine
All the cold air comes from the freezer side so if the fridge side is not cooling then the baffle door is not opening up or it has accumilated ice in it and frozen up. I would try to unplug it for a hour or so with the doors open and let it thaw and then plug back up and let it run for a couple hours to see if that fixes it. If not then I would suggest having the baffle checked.
Apr 29, 2011 | Maytag MSD2656G Side by Side Refrigerator
My Maytag refrigerator Model # MSD2651HEW (26 cu ft , side by side) would not cool there was a rrrrrr noise with a clicking noise and the compressor would heat. I got a factory OEM part from Sears and...
Did you lay down the fridge while cleaning it? if so: Normally if you lay down your fridge the compressor oil is running into the pipes that carries the gas to cool the inside. if that oil is in the pipes you have to shut it down for at least 2 days for the oil to return to the compressor, if not layed down, the chances are that you running out of gas and had to have it refilled
Dec 11, 2010 | Maytag MSD2651 HE Side by Side...
My dometic fridge, (3 Way) for the past couple years takes quite a while to reach it's normal operating temp. I'm talking anywhere from 10 to 15 hours. Once it reaches it normal temp it stays cold until we...
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Jun 21, 2010 | Dometic RM2652 Refrigerator
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
I have a maytag side-by-side frig and lot my owners manual. I just need to know how to change the filter?? where is for that matter ??
I have a side by side fridge also, its not a maytag, but my filter is in the back on the fridge side, not the freezer side of the fridge, i turn mine in the direction its to remove it, i believe its turn to the left and pull down the filter will then need to be pulled out, just pull down on the old filter and throw away, then push the new filter up untill its secure, mine i have to push up hard to get it secure, then replace the cover after washing it........hope this works for you or helps you.....
Jan 06, 2010 | Refrigerators
Maytag plus side by side. Changed pumps and filter and still slow flowing water. Water was shut off due to leak in line for about 1 month prior.
Sounds like you covered all bases except for the supply line from the house.
My procedure is to shut the main water valve at the meter, then remove the water line from the fridge, place it in a bucket, and have someone go to the valve at the meter and turn it all the way one for a 10 or 15 second count. The water should come out forcefully, if not, replace the line and more importantly the valve were it connects to the house line.
P.S. Small chance, since it was shut off for a month, the water reservoir in the fresh food side started to freeze, but time and usage would clear that out.
Nov 02, 2009 | Maytag MZD2766GES Side by Side...
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Maytag MZD2669KE Side by Side Refrigerator Logo
57 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
