Question about CyberPower 525SL (CPS525SL) UPS System
My wiring fault light is on.
What does it mean when the wiring fault light is on. I don't know how long it has been on. Does this indicate the wiring is bad on the back up or the input power supply.
    Scholar:
  • 134 Answers
The input power is bad (outlet) it could mean your phase and neutral are backwards. What country are you in? If in USA home depot or lowes sells cheap outlet tester that let you know right away what wire is wrong
Alex
www.CAS411.com
Posted on Feb 22, 2009
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
I have a 2003 lexus ls 430 my check engine light came on with the vsc off, and exclamtion mark all at the same time and I don't know what that means?
Hi there:
When this comes on as it has it means: When the center differential is locked, VSC control turns off and the VSC OFF indicator illuminates. This is straight from the Lexus diagnostic chart.
The system is faulted in some way so you will need to have the fault memory read out, and then depending on what fault code or codes are stored will determine the type of diagnosis that will need to be performed.
A dealer would be your best bet to get the cause determined. Their scan tool, when hooked up to you vehicle will give them all of the information they need to rectify your condition. After the scan results are found, replacement parts or adjustments can be performed.
Hope this helps.
Jun 04, 2012 | 2001 Lexus LS 430
41 thrt val sol
P0041 Oxygen Sensor Signals Swapped Bank 1 Sensor 2/Bank 2 Sensor 2
looks like your wires and melted together or a rodent has chewed them
Feb 10, 2012 | Mitsubishi Montero Cars & Trucks
I have a Hotpoint SDW 60 problem! The dishwasher starts and goes through pre-wash but stops with just the 'Delicate' light flashing. Does anyone know what the problem may be?
If the original light flashing that means it indicate a fault in the heating circuit. Heater, wiring, thermistor / pcb. (Main control board).
The new flashing light, PreWash (this is the only one on my list for a fault code indication). indicates a fault with the thermistor.
You would need to check by taking the door apart that the thermistor hasn't come off it's mount by the dispenser.
You would then need access to and be able to use a multimeter to test the heater and wiring to ensure they are closed circuit.
Jul 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
1998 Plymouth Grand Voyager.........Dashboard instruments quit working and don't light up. Speedo, tach, fuel gauge, temp gauge, and mileage indicators and lights for same stopped working. ABS...
You have some wiring problems shorting out that is coming from the dash board so if you or anyone you know how to use a multimeter to check the wireing harnesses plus check any connectors that might be just very touching the connector of dashboard which means a bad connection to dashboard.
Jun 04, 2011 | 1998 Plymouth Voyager
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Help for the airbag icon flashing -- is it obviously serious, or could it be a wiring issue or other simple fix? It has just begun a system of multiple flashes and then off for several minutes OR a solid...
upon ignition on the airbag diagnostic module will scan the system for any fault, if there is a fault the airbag indicator will flash. The first set of flash signifies the first digit then a pause the next set of flash for the second digit.Combine these two digits denotes the fault code i.e (two rapid flashes means 2 then a pause followed by three flashes means 3 combine these will read 23 this is the fault code but you need to consult this in the repair manual for ford cars to get the particular fault.Repetitions of 5 sets will occur then steady light on for the airbag.Just replace the instrument cluster and replace the busted bulbs for odometer and turn indicator
Feb 01, 2010 | 2003 Ford Escape
Delicate light flashing will not dry
Post more information about your problem if you need more help....
Good Luck!!
Thanks
Aug 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Light blinking on D4my 1993 accord has the Drive4 indicator light blinking and since that has started the car will not down shift automatically. Anyone know what all this could mean?
the light blinking is an indication that a fault has occured in the automatic transmission, u will need to have Honda test the system for a fault code to determine the exact problem
Jun 25, 2009 | 1993 Honda Accord
Blinker
hi i presume you mean your indicaters won,t work since you changed your headlights firstly are the headlights the same as you took out and the wiring connectors the same and what do you mean the indicators don,t work example none of them they run to slow/quick its just the front ones just let me know and we will see if it can be put right yates210456
Sep 17, 2008 | 1994 Honda Accord
CyberPower 525SL (CPS525SL) UPS System Logo
621 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
