Question about Miller Welding Tools
Wire feed not working Miller 250 mig welder
Wire feed rheostat spins around and around does not stop.
Could there be a problem with the rheostat that causes the wire feed not to work.
Can I test voltage at rheostat? If so, what would I be looking for at each of the 3 leads coming out of the switch.
Also fan does not come on when main switch is turned on. Is this normal?
  • richjariola Feb 23, 2009
    Thanks for the help. I took the potentiometer apart and it was broken inside. I made a temporary repair and now the welder is feeding fine. I will order a new pot tomorrow.
Miller 210, Started to weld, but when i release the trigger the wire keeps running. I shut off the machine to stop the wire, but now when i turn it on the wire motor wont work.
Posted on Jun 29, 2011
  • 169 Answers
If the knob spins all the way around (and especially of it didn't always do that), it's broken. This could mean that the nut that holds the rheostat in place has come loose, or it could be that the wiper inside the rheostat has broken off the shaft. To find the voltage measurements, correct schematics, etc, I'd need to know the serial number of your welder.
Posted on Feb 23, 2009
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Spoolmate 100 wont feed
Check for binding int he inner sleeve first, then increase tension as long as feed motor spins. If feed motor does not spin check wiring to make sure it is connected correctly.
Sep 18, 2012 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
MIG welder 250 feeding wire at erratic speeds
Gun trigger contacts or switch circuit is closing somewhere (shorting). Unplug connector and jump the two terminals if it works and will weld disconnect jumper if problem persists it is not in the gun or cable hose. Keep chasing it far as possible without taking bolts or screws out of machine unless you know what that stuff inside will do to you, pretty sure the problem is not in there anyway.
Apr 02, 2012 | Miller Welding Tools
I have a IRON MAN 250 Mig Welder. that the wire don't feed, with regularty. I have a miller with the same tourch that dose the same thing. If you pull about 4 or 5 inches of wire out, with trigger...
If you see rust on the wire then you should stop and change the gun's liner, change the contact tip and clean the feed rolls. Rust can accumulate inside the gun and make the wire feeding a problem.
Aug 21, 2011 | Hobart Welding Tools
Our MillerMatic 175 wire feed cannot be adjusted down enough. The rheostat seems to function, but even the lowest setting is now way too fast.
Your Millermatic 175 has syncronize wire speed-voltage feature in order to reduce the wire speed first reduce your heat (voltage). Try again.
If this was useful to you please vote. thanks.
Feb 10, 2011 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Wire feed does not stop. Not the trigger.
Ck the feed roller contact relay
Jun 02, 2009 | Welding Tools
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
I have a miller 180 autoset that does not feed the wire
If your welder is less than 3 years old your local Miller authorized service center will repair it for FREE. They can also check the serial number of your welder over the phone to see if it is still in warranty. For goodness sake DON'T tell them you've been mucking around inside the welder or they won't be able to help you.
That said, if the welder spins the feed wheels without any wire between them it probably isn't the board. There is the switch in the gun, the board, and the motor and brake assembly all needed to feed the wire.
Oct 18, 2008 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Welding Tools Logo
1,342 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
