Question about Canon Office Equipment & Supplies
Have a pixma iP 3300. nozzle for black ink only blocked. followed cannons cleaning programme as listed, still clogged
    Sergeant:
  • 199 Answers
Replace print head necessary
Posted on Mar 01, 2009
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have put new ink cartridges in my printer but it it not printing the first couple of lines on the page clearly. The rest of the document is fine. Please advise
Print quality issues could be due to dirty or clogged nozzles. Please follow the steps below to clean the print cartridge nozzles:
Clean Cartridge Nozzles (Solution Center):
1. Go to Start, Programs(Windows XP: All Programs), Lexmark 3300 Series, Lexmark Solution Center.
2. Click the Maintenance tab.
3. Click Clean to fix horizontal streaks.
4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
5. Print a document again to verify that the print quality has improved.
6. If you are still not satisfied with the print quality, follow the instructions in this article How to Clean the Print Cartridge Nozzles and Contacts Manually.
Sep 21, 2011 | Lexmark OfficeCenter X3350 All-in-One...
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
I have replaced both the colour and black ink cartridges in my Canon Pixma IP 200 printer, but now it won't print anything. I have tried the computers cleaning programs but that has not worked. Any...
The print head is clogged.Try to unclogging manualy.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0054.
Nov 05, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer won't make complete copy. Continues to
Cannon printers are notorious for clogged print heads using aftermarket ink. This has happened to me many times before I switched brands. Cannon won't even replace the printer if they find out that you didn't use Cannon ink. Epson and Brother have very good compatibility with aftermarket ink. Kodak are good as well. I recommend these because the cost per page is lowest with these printers AND I use them with great success.
Aug 02, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Re Canon Pixma 4000 black ink is not printing colours are printing Computer not used for 6 months
Canno ip 4000:
please go to the maintenance tab.
This you will find if you try to print anything.
In the print box >go to properties>go to maintence
Here the following Maintenance option are there:
cleaning,
deep cleaning,
Head Alignment,
Nozzle check.
Before your start maintenance, please check whether all print tanks have ink in them
Do a Nozzle check first, this will indicate where you have the problem. Once identified, you can do a color cleanig or a deep cleaning.
Do a Nozzle check again.
You could repeat this cycle about three times or so.
If your problem still persists, then its probably the Print head with jammed nozzles.
Please let me know whether you could solve it.
Please do rate this solution and thanks for using FixYa.
Mar 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Does not print black...
I have had this problem with the Pixma ip90. My machine did not like generic ink ie NON Canon. The ink had clogged up the nozzles. It was only when I put in genuine ink and cleaned and cleaned that I slowly rectified the problem.
If this does not work you may need to replace the printer head.
Good Luck
Mar 16, 2008 | Canon Pixma MP800 All-In-One InkJet...
176 people viewed this question
old marine
old marine
