Question about Intel D845GLLY Motherboard
Boot up beep codes, intel d845glly
i m using intel d845glly board,
last week suddenly my pc stopped working,
there is no dispaly and its giving some beep after each 15 sec,
beep are continuous until i off the switch,
can anyone tell me what the prob is,
and i cant identify which bios i m using..
thanks...
  • mayurshah01 Feb 22, 2009
    i really appritiate ur solution but the beep pattern given in tat link doesnt match wit the one i m facing..
    i m getting continuous beep after each 15 sec interval..
    these beeps are endless..
    and when i remove ram it gives three long beep so can u help me to findout which bios is tat..
    Scholar:
  • 134 Answers
Here is a list of all beep codes : http://www.cas411.com/ShowArticle.aspx?ID=54
try to identify the beep pattern, it should tell you what's wrong. Most of the time, it's a bad memory stick.
Alex
Posted on Feb 22, 2009
NO beep no display.
Hello try to renew the power supply, with one you know is working.
I think the power supply is not giving enough power, or have burned a power rail.
Here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=d101ggc
But the mainboard could also be failing itself.
Look also here:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Feb 23, 2013 | Computers & Internet
Please help me i could not find sound driver for my pc last 1 month my pc p4 zenith motherboard no-d845glly & write now window xp 2000 profesitional instal so how can i solve my problam.
You can find your download here;
In the search downloads window, type D865GBF and click search downloads.
Find downloads by catagory-choose "desktop boards"
Select a product line-choose "Intel 865 series.."
Select a name-Choose Intel desktop board D865GBF(67)
Choose your operating system
Then select "drivers"
This will show your drivers. Pick most recent(top)
Mar 25, 2011 | Intel Desktop Board D845GLLY Motherboard
I have Intel Desktop D845GLLY motherboard, recently it has no display and when power is on it gives three beep. I have a intel board that was running find until i upgraded memory and changed the dvd...
The three beeps tells you that something inside the system is not properly installed. Check all hardware installations and position properly all hardware not properly installed. If nothing is improperly installed, try cleaning the RAM with a piece of clean cloth and install properly.
Feb 20, 2011 | Intel Computers & Internet
No Dispaly Intel D845 GLLY
check the all power cable. change the motherboard battery. remove the ram, agp, then add togther. change the power supply.
Jan 23, 2009 | Intel Desktop Board D845GLLY Motherboard
NO Display, POST or speaker beep
clean your cpu and put new heatsink compount
clean ram contact using student eraser
if you have postcard so you can judge problem
Oct 27, 2008 | Intel D845GLLY Motherboard
Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
Jul 16, 2008 | Intel D845GLLY Motherboard
Graphics card
Hi Harikris, no you can not install just any graphics card. You're Intel D845GLLY board uses an onboard graphics card. (It's an AGP graphics card).
If it's you're intention to install a new graphics card you must use a PCI graphics card. (Understand that the AGP onboard graphics is faster than a PCI graphics card). However, the PCI cards do use their own memory. (Which fee’s you're system memory to run windows.
The Intel D845GLLY has 4 PCI (White) slots, onboard. You can add a video card into the system. You're onboard video card does use you're system memory to function. If you're PC has 512MB of system memory & you're video card is set to use 128MB of memory. Than you're system is left to run with 128MB. One would think you're system is running a little slow.
The Intel D845GLLY motherboard can use up to 256MB of system memory. You can set the amount of system memory in the bios as shown on page 49, table 18. In you're manual. If you do not have you're manual you can download it from here: http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
May I suggest you increase you're system memory to 1GB. Than increase you're graphics memory to 256MB. You're system will run faster & so will you're graphics card. These older Intel motherboards require memory current for you're board. Click this link: http://www.memory-up.com/Memory/IntelD12696.html
If you still feel that you want to use the slower PCI graphics card you can choose from any listed on this link: http://www.newegg.com/product/ProductList.aspx?N=2000380048+1069609642&Submit=ENE&SubCategory=48&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-NA-_-NA-_-NA
You will also need to change a setting in you're bios to boot to the PCI card instead of the AGP onboard card. Page 49.
Good Luck!
M
Jun 04, 2008 | Intel D845GLLY Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Sound driver
i want intel desktop board d845glly mother audio driver
Jan 19, 2008 | Intel Desktop Board D845GLLY Motherboard
Intel D845GLLY Motherboard Logo
235 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
