Question about Yamaha RX-V1800
Yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Hi. i have the yamaha rx v1800 and on my outdoor speakers i cant get any other impot to work other than the tuner eg im running my ps3 through the hdmi imput bd/hd dvd, it works fin on the main zone but nothing through the 2nd zone, but it works fine with the tuner... in the automatic set up it get a warning w3 but i cant understand how that will effect it
Cheers
Dave
  • Anonymous Feb 27, 2009
    i'm having the same issue. at one point, i was able to run the music channels from time warner through the 2nd zone and now that doesn't work either. the only thing i can get through zone 2 is the tuner. any suggestions?
  • achop Apr 01, 2009
    I also have the exact same problem. I have my XBOX connected to my reciever and want to stream music to zone 2. I cannot get any sound output to zone 2, except from the Tuner.
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Posted on Apr 03, 2009
I cant get zone 2 to work on my yamaha rx v673. They are 2 outdoor speakers.. please help
I had a similar problem where I could not increase zone 2 volume - Page 100 in the manual notes that 'power amp assign' must be set to "7 Ch + 1 zone" before zone 2 max volume can be changed. Try that.
Jul 08, 2012 | Yamaha RX-V663 Receiver
RX-V1800. Zone 2 speakers stopped working and I have no sound coming from them. Suggestions?
go to system setting, find Zone2 option, reset output to inner SPK
Mar 19, 2011 | Yamaha RX-V1800
Have no sound when I connect the rear speakers
Open the "Menu" on screen, go to "manual setup" then "speaker setup" check your settings on "surround rear" and "surround back" If your not using zone 2 and zone 3, in the menu for zone 2 amp, select "Ext" and "Ext" for zone 3. If you still have an issue, post a comment and I can help you some more. I am a Yamaha Dealer. Hope this helps
Jul 03, 2009 | Yamaha RX-V1800
Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Mar 15, 2009 | Yamaha RX-V3800 Receiver
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Hookig up rxv1800
This should put you on the right track...
https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_rx-v1600.pdf
You'll have to register but it is free to do so.
Login HiFi Engine
Aug 14, 2017 | Yamaha RX-V1800
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
NO sound on Zone 2
Did you use the same terminals or two different ones to make the connections?
May 18, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V1800 Logo
1,068 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
