I have a 4009 NAC extender. The trouble notification is on on the main panel with the description ''NAC panel open ckt'' Inside the 4009 the led's indicate an open circuit trouble and the 4th led (the ones in a straight line) is flashing. This apparently indicates a trouble with NAC 4, but I don't know exactly what that is. What causes an open circuit trouble in the system. It seems that we saw this same indication a few years ago and Simplex service installed new back-up batteries. I see that there is a different led indication for low/dead batteries but is this open circuit trouble related? Please advise
ctf1800
  • 4402 Answers
SOURCE: HP Pavillion automatically restarts after shutdown
indication of a failing power supply??? I dont think so.
more like a driver is corrupt or better yet have the on board nic card set to turn on, is there a plug that has wire attached to the nic card, unplug those and see what happens.
Posted on Jan 21, 2008
sri2008
  • 53 Answers
SOURCE: computer was working earlier, turned off unit - later tried to turn it on but it won't work
first if u have an ups disconnect the system from that and test the system directly from mains,
If not u disconnect the powerswitch  from the m/b and direct short the pins in m/b.
2. even it is not working u check the system with another SMPS
Was this helpful to u pl give the rating
Thanks
Posted on Feb 22, 2008
SOURCE: battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Posted on Aug 17, 2008
SOURCE: Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
Posted on Nov 06, 2008
  • 2712 Answers
SOURCE: LED Indicator Problems & Flasher Relay?
Modern Ducatis (and cars) don't have a conventional flasher. The blink rate is controlled by the dash cpu. The blink rate change is used to indicate that a bulb is out (by sensing low resistance). Using a resistor will fool the cpu into blinking correctly.
Posted on Nov 20, 2008
99 Corvette Headlights open and close for no reason When I'm driving down the road they will just pop up and a little while later close. Then I hear what might be a motor, Any suggestions? Thanks, Don
Could be the switch going bad or a short in a wire. If it had ever been in a accident that is where i would look for a broken or smashed wire.
Sep 30, 2017 | Cars & Trucks
I'm trouble shooting my Vizio e550i-2b It has power no backlights, image can be seen with a flashlight, I've replaced led driver board and problem persists, do you suggest main board next?
If you can see an image with a flashlight and you can control the tv with the remote then the main board is not the problem. You've replaced the LED driver board, so that leaves the LED strips inside the LCD panel as the likely problem.
Feb 11, 2017 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
I got 99Cadillac Seville and I can't open trunk button not working
Does it have keyless entry , does it open with keyfob ? This is fairly complex ! It would be hard to diagnose from here ,need to hook up a factory scan tool to see if the switch signal is present at the ( IPM ) an see if open message is sent to the RIM module !
Rear Compartment Lid Release Circuit Description
When the rear compartment lid release switch is pressed, ground is applied on CKT 1576 (BLK) at terminal D5 connector 1 of the instrument panel integration module (IPM). The IPM will send a message via the class 2 data line to the rear interface module (RIM). The RIM applies ground to CKT 1344 (LT BLU), with the valet switch in the ACCESS position, voltage is applied from the ALDL fuse 4, through the TRK REL relay coil. The relay energizes, the contacts close and voltage is applied from the BODY fuse to the rear compartment lid release solenoid. The solenoid is connected to ground G402 via CKT 850 (BLK).
May 22, 2015 | 1999 Cadillac Seville
What, besides battery failure , causes 4009-9201 panel battery trouble alert on 4010.
My problem turned out to be with the board and the output of the charger was too low. It needs to be about 27.5 volts. The transformer was okay but the circuit that controlled the output was bad and even with adjusting the potentiometer we could not get the charger to put out the correct voltage. The fix was a new board from Simplex. We got a deal as the tech that came out had the board on his van . Labor and parts were $1,100.00. We get a lot of spikes where we are in Arizona and suspect that a bit of a jolt from a spike or nearby lightning strike wounded the board. A surge protector can help but a hard hit will toast this board.The trouble sensor looks for a full output charge or it will show a trouble
Hope that helps
May 09, 2014 | Simplex 4009-9001 Nac Power Extender Panel
I have power to the door lock switches on the drivers door but the locks do not work nor does the back hatch or the switch at the back hatch that controls all the locks in the vehicle. Do the locks g
Power Door Locks Circuit Description
The power door lock system incorporates door lock switches on both front doors and on the RH D-pillar, door lock motors in all passenger doors and in the RR cargo door, a door lock relay and a door lock control module.
Power for the door lock switches and the door lock control module is supplied from the CIG LTR fuse 13 through CKT 640 (ORN). Power for the door lock relay is supplied from the PWR ACCY circuit breaker through CKT 540 (ORN). Ground for the door lock relay is supplied from G202 through CKT 150 (BLK) and ground for the door lock control module is supplied from G400 through CKT 150 (BLK).
The door lock motors are reversible and both sides are connected to the normally closed contacts of the door lock relay. Those contacts of the relay are connected to G202. When any of the door lock switches are placed in the lock position, voltage is supplied through CKT 195 (LT BLU) to the relay lock coil. Since the other side of the lock coil is connected to ground, the coil is energized and it pulls the lock contacts closed. Voltage is then supplied through CKT 295 (GRY) to all the door lock motors and the doors lock. The unlock function operates in much the same manner except that when any of the switches are placed in the unlock position, voltage is supplied through CKT 194 (WHT) to the unlock coil of the relay and CKT 294 (TAN) supplies voltage to the apposite side of the door lock motor and the doors unlock.
Door Lock Control Module Description
The door lock control module is used on vehicles equipped with cargo doors. The purpose of the module is to lock the cargo doors after a lock cycle has been commanded from any of the door lock switches with the cargo doors open. When the RH cargo door is open, the module receives a ground signal from the closed contacts of the rear door jamb switch on CKT 1897 (ORN/BLK) to G400. When a lock command is received, the module retains this input until it receives an open input from the rear door jamb switch. Then the module sends a lock command through CKT 194 (WHT) to the door lock relay and the doors lock.
Rear Cargo Doors Description
The power door lock motor will not operate unless the rear cargo doors are fully closed. The power door lock motor is in the right cargo door. The contactors are on the rear cargo door opening on the body and on the right cargo door.
May 23, 2017 | 1997 GMC Yukon
Hi I have a Sony Bravia KLV-40S200A which wont turn on. The standby button flashes five times then pauses for about 4 seconds then flashes again. Any ideas?
Diagnostic Test Indicators
When an error occurs, the POWER LED will flash a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first.
LED ERROR DESCRIPTION CODE
1 Supply Voltage Trouble Panel 5V UNReg (10.5V)
2 DE5V Voltage Trouble FE5V (DCALERT2)
3 Voltage Trouble D3.3V/D2.5V/D1.8V. (DCALERT1)
4 Backlight Trouble
5 Main Supply Voltage Trouble (17.5V.DET)
6 Speaker Applied Voltage Trouble
7 Monitor an Increase in Inside-Temperature (esp. on the panel side)
8 Trident IC Trouble
Apr 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Diagnostic code P1516
Hi
Click on the following link for repair instructions http://www.aatecusa.com/obdIIpro/membersonly/technical-tips/obdii/GM_TSB_03_06_04_041A.pdf
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Description of Trouble Code: P1516
TAC Module Throttle Actuator Position Performance
Possible Causes:
TAC motor CKT 1 or CKT 2 is open, shorted to ground or B+ Throttle actuator motor CKT 1 is shorted to CKT 2 Throttle actuator motor control module has failed TSB 03-04-06-034 contains a repair procedure for this code
Jan 03, 2011 | Chevrolet Equinox Cars & Trucks
The green led begins to blink very fast. The screen is dark and the monitor is cold.
that only standby mode, not yet power on. you need to check first power ckt are going to main ckt. trace parts by parts for possible defective or change value parts.
Apr 04, 2010 | Dell P1110 21" CRT Monitor
Comfortmaker furnace fires sometimes
is there any led lights inside the fan cabinet that blink a code if so write down the code then check inside the panel it might tell you the code description if so let me know what the description is and we can procede
Jan 06, 2009 | Heating & Cooling
Computers & Internet Logo
395 people viewed this question
David Payne
David Payne
