Air wont blow thru front vents only thru defrost vents only AIR/HEAT BLOWS OUT OF DEFROST VENTS ONLY
There is a flap in your heater box that is controled by your vent switch by your heater controls. listen for a vacuum leak. that is common and hopfully the problem. there is vacuum lines that control the vent door that redirects the air to your vents.
Has your dash been messed with recently? if so i would check there first. you should hear a hissing if thats the problem.
Otherwise these also are common for that door flap to break and not switch NE more. thats the only 2 things that i can think of off th wtop of my head to be the problem. this would require the whole dash to come apart if its this problem
Michael
ASE certified
It may be your vacuum lines. I had the same problem with my van. The heat from your engine causes the lines to break. To fix it I looked under the hood, and found where the lines had been. If you take the whoe air filter assembly off you will see them running over the engine. To fix I just put slightly biger tubes over the broken ends that fixed it. You can get tubing from your locl autozone.
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
heat blows out of the defrost only theres a yellow vacum not attached and a black vacum line under the hood i cant find a spot to attach them
not blowing hot air an air only come thru defrost vent
