Question about D-Link AirPlus Xtreme G DI-624S Wireless Router
I have connected an HP Photosmart 2570 series to the D-Link DSL-G604T. The printer appears in Printers and Faxes in Control Panel but when I print I get a message to the effect that the document couldn't spool because the printer is either unplugged (its not) or it is attached to a VPN which will block access. What do I do?
    Scholar:
  • 31 Answers
Please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Posted on Mar 14, 2009
My printer will not print any jobs because the magenta ink is low. I don't want to print in color only black. Please help. My E-mail is affordableauto@frontier.com.
Please click on Start on the computer------Control panel-----Printers andd Faxes.
Right click on the printer iconx Photosmart C6180 series------Properties-------Advanced.
Here, please select the option "print in grey scale" and click OK.
This will fix the issue and you will be able to print in black only.
Jul 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
Text has shadows
Run the print head clean wizard in the control panel under printers/faxes section. If that dont work run the alignment wizard. One of these most likely fix it.
May 24, 2009 | HP PhotoSmart P1000 InkJet Printer
My HP 2610 defalt has changed to fax instead of print mode
follow this trouble shooting steps your issue should resolve.
On Computer:
Click on Start >> Control Panel >> Printer and Faxes >>
check which Icon is enabled if Fax is Enabled Just Disable it By right clicking on it and Disable.
Now Right Click on Printer Icon then select " Use Printer Online"
then set it as Default Printer.
Now try to print your issue should resolve..
I hope it helps ...raj 9866486995
Raj....
Feb 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
Computer/rinter Problems
Normal 0 You probably already did it like this
Disconnectthe printer or at least be sure it is turned off. I'd doboth and when the CD software program asks you to connect the printerto the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 28, 2009 | HP Photosmart C6180 All-In-One InkJet...
C5180 printer
These are the steps for WinXP
For windowsVista after control panel go to Printer or hardware and sounds to go to printers (Then rest same as WinXP)
First check the printer icon. ( Make sure the printer is turned on during this process)
Go to Start> Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware)
And check that the printer C5100 Series has a check mark.
If not right click on the same and left click on Set printer as default.
Next make sure the printer icon says 0Ready.
If not right click on top of the C5100 Series icon and left click on Clear all documents (untill it says 0ready)
If it still does not say 0Ready, then restart the computer and check to print any document.
If you do not see the C5100 icon then you may have to install the printer driver ( If is is already installed)
Then unplug the USB cable which is connected to the printer end and leave it unplugged for atleast 1Mins before reconnecting>
After reconnecting it should install the printer diriver on its own>
Then
Go to Start> Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware) then C5100Series.if it says 0Ready>Right click on the same icon and left click on Properties>
Now in this window towards the bottom right you will see a tab which says print test page>Click on it to see if it prints a test page.
Sep 27, 2008 | HP Photosmart C5180 All-In-One InkJet...
Installing the printer
hi sir
go to control panel>
printer& fax>
double click on the add printer>
select the type> and follow the step> by inserting the printer software> it work's thank u.
Sep 03, 2008 | HP Photosmart 2575 All-In-One InkJet...
Back again....please help
Try this. Go to Start, Printers and Faxes, right click on your printer. When the menu opens make sure there is NOT a check mark next to "Use Printer Offline".
Jun 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer problem
no harm in reloading try it. please get back with your findings
Apr 02, 2008 | Office Equipment & Supplies
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
D-Link AirPlus Xtreme G DI-624S Wireless Router Logo
246 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
