Question about Uniden BC72XLT Handheld Scanner
I have a uniden ubc73xlt handheld scanner,can't program channels, keeps saying locked out, have tried to unlock as per instructions but not unlocking.
  • Anonymous Mar 25, 2014
    scanner wont turn on
  • 4 Answers
Try a master rest:
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
Posted on Feb 24, 2009
Says all channels lock , and all scanner mode locked.
see the user manual here...http://www.cabelas.com/assets/product_files/pdf/636073_uniden_bc125at_owners_manual.pdf
it says: Unlock all Channels in Banks Currently Enabled for Scan 1. Press Hold to stop scanning. 2. Press and hold L/O until Confirm Unlock All Channels? appears in the display. 3. Press Pgm/E to unlock all or. Clr to cancel.
Dec 03, 2015 | Uniden Bc125at Handheld 500 Ch. Special...
Can't unlock channels they are all showing l/o.
Look to see on the keyboard that has a button that looks like a key with a
border around that button. That'll be you L/O button place the scanner on
Manual then keep pressing Manual for each channel. If you see the letters
L/O << looks like that press the lock out key the those letters "L/O" Should
Disapear.. Keep doing those steps untill all channels a clear.. I say this
because this is how my Uniden 30 channel hand held works..
Yours may work diffrent? Hopefully it works the same.
Jan 22, 2012 | Uniden BC60XLT-1 Handheld Scanner
Hi there is there an online manual for ubc73xlt?
Yes. You can download/print the manual here:
http://www.uniden.com.au/resources_main/pdfs/UBC73XLT_OM.pdf
Bill B
May 12, 2010 | Uniden BC72XLT Handheld Scanner
PROGRAM AFTER ALL LOCKOUT OF ALL CHANNELS ON A BC60XLT-1 SCANNER
With the channel display showing 000.0000 you may be able to program a new frequency into it, and the new program will release the lockout. Have you tried the normal programming for any channels?
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
How do i programme channels into my UBC73XLT uniden scanner plz
- Power the scanner ON
- Press HOLD to stop scanning
- Enter the channel number that you wish to program
- Press FUNC then PGM (Channel number will show)
- Enter the desired frequency, including the decimal point
- Press E to confirm
Need the manual for your scanner? You can download/print it here:
Dec 27, 2009 | Uniden BC72XLT Handheld Scanner
Cannot unlock Uniden BC60XLT-1 (30 ch VERSION)
if all the channels are 000.000 then it wont scann youll have to hit manual then enter a freq then hit the "e" button. once you hit manual youll be able to push the up and down arrows to select an channel you wish to imput a feq. Hope this helps.
David
Jun 29, 2009 | Uniden BC60XLT Handheld Scanner
I HAVE A UNIDEN UBC73XLT
The BC72XLT is a USA model scanner, while the UBC73XLT is produced for Australia and New Zealand. The two are very similar, but not identical. There is a slight difference in frequency coverage (it's a bit wider on the UBC), the BC comes with a 110-volt AC power supply (wall-wart) for USA use, while the UBC comes with a 12-volt DC vehicle power supply.
FYI, here are links to the operating manuals for both models:
http://www.uniden.com/pdf/BC72XLTom.pdf
Feb 16, 2009 | Uniden BC72XLT Handheld Scanner
L/O is on all channels cant program with L/O on it
push manual then hold down lock 0ut button for several seconds this should unlock all
Feb 14, 2009 | Uniden BC60XLT Handheld Scanner
Scanner problem
To unlock a channel, press 'manual' & keep pressing it until you reach the channel that's locked out, then press 'L/O'. Repeat until all channels are unlocked.
To program, press 'manual' until you get to the first "empty" channel, then enter the desired frequency using the keypad, then press 'E'. Repeat as needed.
Dec 21, 2008 | Uniden BC72XLT Handheld Scanner
Can not unlock channels
http://www.uniden.com/pdf/BC60XLTom.pdf
May 02, 2008 | Uniden BC60XLT Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
838 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
