Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Shuts off after about 10 mins. - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
    President:
  • 389 Answers
Hi!  This is the sign of a machine that is overheating, and almost certainly is caused by a partial blockage.  You need to check all the pipework and make sure the washable filter is clean (if you wash the filter, use only clean cold water, no detergent, and let it dry in a warm place for at least 12 hours, do not force-dry). I hope this helps.  I value your feedback, so please remember to rate this response. Good luck!
Posted on Feb 22, 2009
Hoover vacuum shuts off after 10 minuts of use.
If there is no clog the filters may need replaced to improve airflow
Jan 21, 2014 | Hoover Vacuums
Vaccum afuera 550 start few minutes and stop few secondes, after 10 min its stop 30 sec and start 3 sec, after 20 min start ok
Your vacuum may be clogged, overheating and shutting off. Check for obstructions in the hose by laying it as straight as possible and shining a flashlight in one end while looking thru the other end. If you have a curved hose end, try holding the suction hose from another vacuum while checking for airflow in the opposite end.
Nov 06, 2013 | Electrolux Central Vacuum
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Eureka maxima heats up and shuts down after 10-15 minutes use??
sounds like you have a clog some where or need to replace your filters. your machine is tripping the thermal switch thats why it only runs for 15 min
Apr 02, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My hoover Windtunnle model U5781-900.turns off while in use. After sitting for about 30 min it will work again for about 10 min and then shut off agian.
This is a result of the motor overheating. Try cleaning the filter above the dirt cup. Remove the dirt cup and right above should be a grey plastic cover. Slide the lock to get to the filter. Once you clean the filter, allow it dry and place everything back the way it was. This should allow the vacuum to work much longer.
Jan 15, 2011 | Vacuums
Dyson animal shuts of after 5-10 min of use
The "hidden" filter at the base of the unit is the HEPA filter, there is another filter on the side of the vacuum that you can remove and wash with water. Make sure that is washed out. If it's too dirty it will restrict air flow and the motor will overheat.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
EL7020A ELECTROLUX VAC SHUTS OFF AFTER 10 MIN
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Feb 10, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Shuts off/ peppershaker24@msn.com
it is overheating clean all suction ports well, as well as the brush. clean or replace all filters, especially the hepa. Hopefully the damage is not irreversible, if so the motor is most likely done for.
Oct 31, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
108 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
