Question about Nikon D80 Digital Camera with 18-135mm Lens
Hi i have borrowed a friends camera nikon d80. I had been taken pitures dueing the day but at night time the pituers wouldnt come out at night so we had a play with it. Now we cant get anything. On the back of the camera there is a green light flashing. when i press the menu this comes up high lighted , a spnner then LCD brightness o comes up.How can i clear it. Thanks for your help paul.
  • 423 Answers
Hi thanks for coming to FixYa. To solve your problem do this:
Find the two buttons with green dots next to them on the top right of the camera. They are the +/- and the AF buttons. Hold them both down for a few seconds. The top lcd will blink and everything will be back to normal.
Rob
Posted on Feb 28, 2009
My D80 fell from a foot n half above the ground level well packed in a good quality carry case few days back.uv filter attached to 18-135 Nikor lens cracked & lens cap was jammed. After carefully...
Hi, allow me to suggest using another lens to see if you still see the dark patches in the top corners. If not it is the lens, if so it is the camera. Either way it sounds as though something is maladjusted. Call Nikon digital 1-800-645-6689.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
I was told that i need to replace my shutter on my D80. and it is only 2 years old. is that a normal thing?
A Nikon D80 shutter is rated to fire 100,000 times. Have you taken that many pictures in 2 years? If so, that means you've shot about 137 pictures a day for 2 years!
Dec 04, 2009 | Cameras
Nikon D80 error message rEE
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blue corners when shooting in BULB
With the same exposure settings, you should get the same result. When using Bulb in Manual mode, you also need to be sure you have set the lens aperture to the largest opening (lowest number). And don't forget to set ISO to 1600. Since the D80 has shutter speeds as long as 30" (minutes) I recommend you use them instead of Bulb, unless you need longer.
The blue areas are heat noise from long exposure -- other electronic components near the sensor are generating heat from the constant current flow. Be sure you check your Shooting Menu settings to set Long Exposure NR to ON and also High ISO NR to HIGH.
Apr 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80 with an 18-135mmNikkor lens.  It's about two months old.   Yesterday I was outside, on a snowy day,and a couple of times, I pressed the shutter release button and it would not take a...
i suggest pointing the camera to an image which has more contrast as opposed to pointing it into a clear blue sky which has no clouds at all. the AF might have some trouble looking for cue to focus. go manual focusing and see the difference.
Nov 29, 2008 | Nikon D80 Digital Camera with 18-135mm...
Control Panel display no information.
Do you mean the control panel on top or the big LCD on the back?
The display on top should be showing you stuff like the shutter speed and aperture as you take the picture.
The display on the back will not show you the picture while you're taking it. The D80 does not have a Live View capability.
Sep 17, 2008 | Nikon D80 Digital Camera with 18-200mm...
D80 shutter issue
contactjoni,
Your shutter will stick if it gets dirty or dust gets in the camera, a reputable camera shop can inspect the shutter, the sensor for dust & dirt and can clean it for you. If the battery is low while shooting the shutter can also stick on longer exposures.
randy320sgi
Jun 28, 2008 | Nikon D80 Digital Camera with 18-200mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
80 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
