Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing F2 gets to drain/spin cycle it will drain then won;t spin..makes noise..shows F2
  • 6,784 Answers
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Posted on Feb 22, 2009
  • Michael Masters
    Michael Masters Feb 22, 2009
    When excessive suds are detected, a suds routine
    automatically starts. This routine removes extra suds and
    assures proper rinsing of your garments. “SUD” is displayed
    during rinsing and at the end of the cycle to inform you that
    Suds Routine was activated. Use only HE (High Efficiency)
    detergents.
Why are the clothes still soaking wet after a wash cycle.
Hose could be clogged up.Take hose off and see,maybe run with hose off for a sec.
May 22, 2015 | Washing Machines
Washer not draining but motor still hums
I would get to the water outlet pipe and blow hard down it to try and clear any blockage if not take the pump housing apart to clear the blockage eric
Dec 24, 2017 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
After washing it makes loud noise & won't spin or drain
You shoul inspekt water outlet on the bottom of the drum. There is mabye something inthere.
Dec 02, 2017 | Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have an HE 3 front loading washer and I am having problems with
Hi
Thanks for using FixYa. F2 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed. Press PAUSE/CANCEL twice to clear the display. Also, check the drain hose and make sure it is not plugged or kinked. Then check the electrical connections at the pump and make sure the pump is running. If still the issue is not resolved then replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not draining and spinning
F2 IS A LONG DRAIN CYCLE CHECK TO SEE IF THE WASHER IS DRAINING AT THE WALL IF HOW MUCH CHANCES ARE THAT THE LINT FILTER IS STOPPED UP WHICH IS LOCATED BEHIND THE FRONT COVER ON THE PUMP ONCE YOU FIND THE PUMP YOU WILL SE A SLOT THAT LOOKS LIKE A CLEAN OUT WHICH IT IS IT ALSO LOOKS LIKE A HANDLE TURN THIS HANDLE COUNTER CLOCK WISE AND THIS OPENS THE FILTER CLEAN IT AND PUT BACK IN.MAKE SURE YOU HAVE PLENTY OF TOWELS FOR THIS IS WILL GET VERY WET VERY QUICK
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
387 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
