Question about Dell Inspiron 1300 Notebook
Windows ex dell ispiron 1300 just updated xp and while the wirless connection says its on, the browser nor mcaffe sees the connect
No sound is out when i play my real player also i couldnot connect with friends with yahoo massenger on sound
you will need to go to the dell website look up sound drivers and download it ,also go to control panel select sound and click on to activate ajust volume ,you may need to update java and flash very easily downloadable this should get you listening again
Mar 25, 2011 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
Every time McAffe updates, D-Link wireles manager won't boot.
1. check the power adapter and or the cord for broken plug.
this router could have bitten the dust,
May 31, 2010 | D-Link DIR-615 Wireless Router
I cannot connect to my wireless internet Dell Inspiron E1505
what does the it say? limited connectivity? etc. or it just can't connect at all?
Aug 16, 2009 | Dell Inspiron E1505 Notebook
Does a dell ispiron 1300 have a sd adapter slot
I don't believe so, but you can double-check here:
http://www.notebookreview.com/default.asp?newsID=2738
Aug 09, 2009 | Dell Inspiron 1300 Notebook
Dell dimension 3000 won't see wireless network
Hi, I've jst been looking on the web at the Mimo routers, you may find this article interesting, it may help even though its a couple of years old?
http://www.behardware.com/articles/614-2/wi-fi-mimo.html
Pay attention to part about 802.11n compatibility?
Perhaps try changing the IEEE standard on the router to 802.11g in the set up pages, as it may be set at 802.11n, which your older wireless card will not see.
As to the acquiring ip address message, try using a static ip address, here's a good guide:-
http://portforward.com/networking/static-xp.htm
Maybe this will help?
Jan 27, 2009 | Dell Dimension 3000 PC Desktop
Dell Inspiron 1300 can't connect external monitor
I was having the same problrm for my dell inspiron 1300. It is not FN + f5. It is fn +f8. Notice the Crt/LCD...
Jan 04, 2009 | Dell Inspiron 1300 Notebook
Browsers/ PC
Check there is no proxy server in internet explorer
Open IE
Click Tools --> Internet options
Click Connections Tab
Click Lan Settings
Make sure "Use a proxy server for your LAN" is not checked
Check "Automatically Detect Settings"
Click OK and OK
If this doesn't work check there are no values set for IP addresses in
Start --> (Settings) --> Control Panel --> Network Connections
Right Click your Wireless Connection --> select Properties
Scroll down to TCP/IP in the centre box and Click it to select
Click properties and chose "Obtain Automatically" for both IP and DNS
Click OK OK or Close
Try Internet again
Dec 16, 2008 | Dell Precision M60 Notebook
Wd Hdd inaccessable
try to disable all firewall setings or antivirus...after try accesing frome ur command prompe if u can that the windows is blocking the hdd...uninstall any new software or driver and try again...no effect ok dowload ophcrack live cd frome google and access the hdd by force repare or scan it in surface scan that will fix ur clusters problems that might be in the back off this prob an du know wer e2 go frome there
Feb 12, 2008 | Cavalry Storage Cavalry CAUO37500 500GB...
Dell Inspiron 1300 Notebook Logo
76 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
