Question about Microsoft Windows Vista Ultimate Edition
Windows Installer cannot be accessed. Message shows.I have tried everything but nothing happens.
    President:
  • 2,559 Answers
Method 1: Use the Msconfig tool to confirm that the installer service is running loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the Services tab, click to select the check box that is next to Windows Installer
  4. Click OK, and then click Restart to restart the computer.
If that didn't do it,go to the next step.
Method 2: Re-register Windows Installer
  1. loadTOCNode(2, 'resolution'); Click Start, and in the Search box, type Msiexec.exe,
  2. click Search everywhere for All files and folders.
  3. The location of the file should be C:\Windows\System32
  4. Click Start, and then click Run.
  5. In the Open box, type regedit, and then click OK
  6. Locate and then click the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSIServer
  7. In the right pane of the Registry Editor window, double-click ImagePath.
  8. In the Edit String dialog box that appears, make sure that the string in the Value data box contains the correct path for the Msiexec.exe file that you determined in step 3.
    If the Value data box does not contain the correct path, make changes to correct the path, and then click OK to close the Edit String dialog box
  9. On the File menu, click Exit to quit Registry Editor.
  10. Start your computer in Safe mode, and then register the Msiexec.exe file.To do this, follow these steps:
    1. Shut down your computer, and then restart your computer.
    2. Restart your computer and press the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, press the F8 key when you see the Boot menu.
    3. Use the ARROW keys to select Safe Mode, and then press ENTER.
    4. If the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
    5. Log on to the computer.
    6. Click Start, click Run, type msiexec /regserver in the Open box, and then click OK.
  11. Shut down your computer, and then restart your computer normally.
Method 4: Reinstall Windows Installer
To reinstall the Windows Installer, follow these steps.
  2. In the Open box, type cmd, and then click OK.
  3. At the command prompt, type the following lines. Press ENTER after you type each line. cd %windir%\system32
    ren msi.dll msi.old
    ren msiexec.exe msiexec.old
    ren msihnd.dll msihnd.old
  4. At the command prompt, type exit, and then press ENTER.
  5. Restart your computer.
  6. Update the Windows Installer files to the latest version
  7. After the installation of the Windows Installer is complete,restart your computer normally
    Check the Windows Installer service (Control Panel - Administrative Tools, Services) is running. It should be set to manual or automatic. Also check the dependency Remote Procedure Call (RPC) service is running.
If that don't do it,Try this Open a command prompt.(Start,all programs,accessories,Right click on command prompt and run as administrator) type sfc /scannow
Posted on Feb 22, 2009
Failing to install anti virus on samsung netbook
Sounds like a virus has disabled windows installer.
Click Start/Control Panel/Administrative Tools/Services
When the services window opens scroll down near the bottom and look for Windows Installer. Double Click on Windows Installer then click START when it opens. Press Apply, Press Ok, then reboot and see if the problem is solved.
If not Reinstall Windows Installer:
The reinstall varies depending on your operating system so go to www.google.com and in the search box type "reinstall windows installer xxxxxx" (without the quotes and change xxxxx to your operating system such as Windows XP, Windows Vista, Windows 7).
Click the link and follow the reinstall instructions from Microsoft's site.
Apr 05, 2012 | Samsung NC10-14GW Notebook
My printer can not print. I tried to follow troubleshoot and restarted the spooler nothing happened. It showed the message that says "printer lost its connection to server" the name of the...
did you already try all the set up of your printer?. you said showed error message lost its connection to server that means you need to re install your printer to access the server. you need the CD installer of your printer then run the software so that your printer can now connect to server.
Apr 12, 2011 | Office Equipment & Supplies
Windows Installer cannot be accessed in Windows Vista 32
TRY sfc/scannow command at command prompt u need your operating system cd inserted while the operation
Oct 15, 2009 | Microsoft Windows Vista Home Premium for...
C Drive Access Denied and The Parameter is Incorrect
I found this on a Vista Forum: Re: Access to C Drive
I figured it out -- you have to take ownership of the drive away from
the "TRusted Installer" account, which can be used only by Windows, and
assign it to one of your administrator accounts. AVG did this! So now your C: drive can be accessed by "Trusted Installer" and not you. You are an Administrator so you need to go to permissions and assign the C: drive to you and NOT the "Trusted Installer"
Apr 14, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have tried to down load some updates to my programs and I get the following message: The windows installer service could not be accessed. This can occur if you are running int he samve mode, or if the...
Is you windows at automatic update enable, Ok try this on the RUN dialog box type SERVICES.MSC and press enter and see your automatic update should be AUTOMATIC under the start up type. Doubleclick on automatic update to do changes to the settings and see what happens. cheers
Nov 14, 2008 | Gateway Computers & Internet
New application software can not installed
I SOLVED THIS ON MY LAPTOP BY REINSTALLING THE WINDOWS INSTALLER. THIS PROBLEM USUALLY HAPPENS WHEN THE INSTALLER IS CORRUPTED BY SOME MALFUNCTION. THE BEST SOLUTION IS TO UNINSTALL AND RE-INSTALL THE PROGRAM FROM THE MICROSOFT WEBSITE. HOPE THIS HELPS YOU.
ARCLIGHT1217
Nov 03, 2008 | Microsoft Windows XP Professional
When installing program an error message appears, error 1719 windows installer service could not be accessed
Error 1719. The Windows Installer Service could not be accessed. You may be running in Safe mode or Windows Installer may not be correctly installed
please goto the following link for a fix for this issue.
http://support.microsoft.com/default.aspx?scid=kb;en-us;315346
Sep 03, 2008 | Computers & Internet
I am having a problem with Adobe Reader 8.1.1. I am using Windows XP. Originally the program ran fine, but lately when I click on a link on a website that uses Adobe Reader I get a message that says...
do you the original installer of your adobe reader?
if you..when uninstalling adobe and the error occurs just browse for the .msi in your adobe installer and hit ok...
after it uninstall...download foxit reader and install it instead of the adobe reader....
hope this helps
^_^
Mar 16, 2008 | Computers & Internet
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Microsoft Windows Vista Ultimate Edition Logo
159 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
