Question about Bryant 463AAC008BA Air Conditioner
Bryant a/c heat pump "model 540bj024"
Please explain how to troubleshoot a condenser unit circuit board
  • 1 more comment
  • Farley Redfield
    Farley Redfield May 11, 2010
    Please explain what your problem is and what symptoms are you expierancings. And what is your part no & model no.How many wires are on it where or what they go to.
    This way I wont get you lost nor you get me lost.
    IF THIS HELPS PLEASE GRADE MA ACCORDINGLY and GOOD LUCK.
  • Perry Putnam
    Perry Putnam May 11, 2010
    If you can explain what the system is doing we may be able to help.
  • steve
    steve May 11, 2010
    It depends entirely on what problem you are experiencing as to what to troubleshoot.
  • 358 Answers
Check if you have 24volt out of the board if not replace it.
Posted on Apr 03, 2009
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
Aug 30, 2017 | Bryant Heating & Cooling
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
Have a bryant 3.5 ton outside can I change to a bryant 4.0 ton and still use the same inside equipment
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier. Hope this helps.
Jan 28, 2013 | Bryant 3.5 Ton R22 12 Seer Condenser Only/...
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
My unit stays on even after shutting it off or turning it down. I replaced the thermastat and the problem still acurres. HELP!
have you used the weed eater out by the condensing unit could be short in thermostat control wiring to outside unit or a stuck contactor in condenser control circuit try these first then if not there in furnace control circuit at board that jockeys between air and heat remove thermostat wires from board remember thier location bet it stops.
May 12, 2010 | Bryant Heating & Cooling
Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant a/c heat pump "model540bj024"
I have to start with the wire diagram. Find the circut board. Look for any connections marked to the thermostat and follow to what they go to. See what other controls it has pressure sw, tenp sw, ,,, then decide how its suppose to work.
This may not help you but it is a direct answer to your request. If you need more infor I need more info and spicific  on what you want to check.
IF THIS HELPS PLEASE GRADE ME ACCORDINGLY and GOOD LUCK.
Feb 22, 2009 | Bryant 463AAC008BA Air Conditioner
Troubleshoot condenser circuit board
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
Heating & Cooling Logo
406 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
