Question about HP OfficeJet Pro K8600 Printer
Paper in tray but message says paper tray empty
  • Anonymous May 19, 2009
    the printer constantly says there is no paper in the tray when there is paper
  • HP Master
  • 419 Answers
HP officejets are notorious for problems with paper feeding...
Try the solutions (ignoring the ones about tray #2) from this solution... They're all the same sort of printer feed mechanism.
http://www.fixya.com/support/t878735-printing_error
... also something I noted with the K850 (the earlier model to the K8600).. some papers are less likely to be picked up than others.
I had to get some cheap A3 paper for that unit which worked better than Xerox branded, higher quality photocopier stuff. Sounds strange but if it works...
Hope that lot helps.
Posted on Feb 22, 2009
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
Lexmark T640 printer will not print- get message- media tray empty
Check if the paper tray has enough amount of paper in it. If it has, check if the paper guides are correctly placed and is set to the correct media size.
Aug 02, 2012 | Lexmark T640 Laser Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
Paper Empty in Custom Tray message
there's something wrong with the paper sensor
Jul 23, 2009 | Samsung CLP-510 Laser Printer
What does it meant when the copier has message Load 81/2 x 11 paper type:user type 1
The tray that the copier is attempting to pull paper from is empty. You may have a tray with 8.5 X 11 paper, if you have more than 1 tray, but it is looking at an empty tray.
May 11, 2009 | Sharp AR-M550N Copier
Paper won't feed. Message says paper tray empty but it isn't
Hi
Please press the button above HOME and it should change the tray in which you are printing from .
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Office Equipment & Supplies
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Paper empty message when pdf
Could be a page size problem.
A4 paper in the paper tray, but what page size does the PDF think it is?
Dec 30, 2007 | Samsung CLP-510 Laser Printer
HP OfficeJet Pro K8600 Printer Logo
425 people viewed this question
Ben Johnson
