Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Coffee out of the machine seems too watery
Coffee tastes watery and weak when coming out of machine. Not sure if it is gronding too fine but taste is not good and mahine is unusable at the moment due to this.
  • 1 more comment
  • DanielleMac Apr 30, 2009
  • Anonymous Mar 25, 2014
    operated fine but coffee taste very watery and lots of coffee beans are in coffee
  • helen Apr 14, 2014
    adjust your dose
  • Gaggia Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Coffee only comes out in spurts (not the usual free flow) and tastes watery
How to resolve Saeco Odea Go Issues - YouTube
? 6:29
https://www.youtube.com/watch?v=lRl_D5lBm5s
Apr 27, 2011 - Uploaded by slashtiger1
This video will explain how to resolve the 'dripping coffee' issue and similar ... I am a ******** espresso ****** and my machinehas been down for several weeks. ... and doing the steam outprocess, it still was not pumping out coffee. ... only to brew with the smallest quantity of water, you could try cutting ...Missing: spurts ‎usual ‎free ‎tastes
Jan 12, 2016 | Saeco Magic Comfort 103467 Espresso...
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
My coffee tastes watery. It seems as though the water flowing through the filter is going too fast. My other Keurig at work brews much slower, and the coffee is delicious.
Hi, Your coffee is ground too coarse. Make the grind finer as this will slow down the flow rate. If you go too fine it will just dribble and over extract the coffee."bitter". Dazza REPAIRER
Sep 23, 2011 | Keurig B60 Coffee Maker
No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Aug 01, 2010 | Miele CVA615 Espresso Machine
Saeco Professional- Coffee taste watery and not creamy
Nov 23, 2008 | Saeco Royal Professional Espresso Machine
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Jul 16, 2008 | Gaggia Titanium Espresso Machine
Coffee is weak and watery
After reviewing troubleshooting diagrams, I really couldn't find a solution to your problem.
The only thing I can suggest is to use 2 oz per pot of coffee grounds. Your 5 or 6 scoops assuming they are one ounce each is way more than enough.
Look under where your basket goes. Most bunn coffee maker has a flavor guard on the downspout. this down spout actually helps distributes the water over the whole basket of coffee grounds. Most of the time I see these missing, and when they are gone, they are gone.
Use less water for the amount of coffee you are using first. Sadly when there is not enough water, the coffee tastes bitter. Too much water tastes weak. Hot water extracts certain elements out of the beans even after grinding.
Always use a fresh paperfilter designed for your coffee maker.
If this pot is not work correctly still, I will suggest seeing your appliance repair technician.
May 26, 2008 | Bunn BT10B Coffee Maker
Espresso is dark and rich at first; then shifts to water
This is suppsed to happen, every espresso machine out there on the market does this.
All the taste for the coffe comes in the first couple of seconds and after that it gets less and less.
So the problem is not that it gets lighter and lighter, but that you dont get enough taste in the start of the brewing.
And this can be caused by alot of things.
Bad beans?
Not set the grinding to fine?
it will not heat enought and thereby not get enough taste.
etc.
Apr 12, 2008 | Saeco Talea Giro Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
868 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
