Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lens repaired then new problem - Illuminated LCD screen
The lens was mechanically broken by dropping it. The LCD was fully functional showing images. Then I took the camera apart. Put in a new lens I bought off of E-bay and then I got a fully illuminated white screen when I turned it on. The camera takes and saves pictures but I cannot see the screen. That is the problem. Perhaps it was a loose connection. I reseated all the connection but I had no luck same result.
  • Canon Master
  • 4,738 Answers
The ribbon cable that connects the lcd screen to the circuit board is not inserted deeply enough. Try again, but push it in until it physically cannot go in any further.
Posted on Feb 22, 2009
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
My AF-S NIKKOR 70-300 1:4.5-5.6 G lens will not focus properly. The focus keeps jumping in and out and the motor has gotten noisy. I checked all function controls to ensure nothing got knocked out of...
Your lens is a cheaply-built kit lens intended to be sold as part of an initial body and lens kit.
It's not built badly or with especially poor quality materials, but it's certainly not to the same standard as their non-kit lens offerings and so is not as long-lasting or robust as regular Nikon lenses.
In your case, the focus drive mechanism has broken, possibly due to one of more motor pinion teeth being stripped. If the lens has not been dropped or otherwise misused and is still under warranty then return it to a Nikon service centre for a free repair. If outside of the warranty, then in most countries Nikon offer fixed price repairs, but you'll find it more economical to simply buy a replacement lens. What's failed is not suited to a DIY repair
You can commonly buy new ex-display examples and definitely fully-functional used examples of your lens for a less than the typical fixed repair price. As you don't state which country/stat you live in, I'm unable to provide example prices.
Jun 27, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Screen is black like the lens is closed, I believe the inner lens is not opening.
Are you sure your lcd display isn't broken? I don't know if the lens assembly has an inner screen, but if it's not working, it's the gear mechanism that's broken, and will require servicing. Cheaper to buy a new one, on sale, if the cost is too much to service it. A repair shop should be able to give you a ballpark estimate.
Mar 11, 2010 | Sanyo Xacti VPC-T700 Digital Camera
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Black Screen on Canon PowerShot SD750
Probably bad CCD. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Sep 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lcd screen shows no image
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Canon PowerShot A75 Digital Camera
Lens broken does anyone know where i can purchase one
Here is a link that shows how to replace the broken LCD Screen on the LG KF700. There are links to buy a new KF700 LCD screen
LG KF700 LCD Display Screen Replacement
Apr 16, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
Camera stopped working, lense partially extended
Switch on - lens extends - screen comes up is the normal. Partial extension of lens and the rest does not follow. Why does the lens not complete its function? Probable cause dirt got into the slide mechanism is the simple answer. Very fine mechanism- would not try anything your self. Have you a service facility of watch repair shop near you. Or try the makers web site - they may offer a swap out facility for a modest fee.
May 17, 2007 | Canon PowerShot S60 Digital Camera
Zoom lens jammed
this is a protection mechanism against further damage when the zoom/lens mechanism is obstructed. It's a very delicate mechanism, and it's not easy or cheap to fix. The gears probably got misaligned or broken when you dropped the camera. You should get a repair estimate, and only if you decide you'd rather trash it try opening it up again. Good luck
Jun 22, 2006 | Samsung Digimax 420 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
111 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
