Question about Bryant 463AAC008BA Air Conditioner
Troubleshoot condenser circuit board
Please tell me how to troubleshoot a condenser circuit board.
  • Anonymous Mar 12, 2009
    fuse blows with thermostat plug connected at condenser circuit board. Tried pulling the leads to the compressor contactor but fuse stills blows. Heat from the electric furnace works ok as long as the condenser thermostat plug is not connected.
  • 1,734 Answers
Ask - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
Posted on Feb 22, 2009
How do you install circuit board in atwood furnace 8525? do I need to disassemble most of the furnace to do this?
I am not familiar with the model number. I have worked on all types of equipment and have never seen a system that required major dis-assembly to replace a board. What does it look like from the outside? Up flow furnace, through the wall with a split condenser, horivontal residential? Tell me what you can and l"ll probably be able to tell you exactly where and how. Thanks for trying Fixya.
Sep 11, 2013 | Heating & Cooling
Unit will not lite
Look on the circuit board, is ther a flashing diagnostic code?
tell me this code sequence.
Typically an induced draft motor will be the first thing to run, is this running? is the pressure switch for the induced draft operating, it its tubing and the tubings ports clear?
is the condensate line clear?
is the flame sensor clean? use 0000 steel wool to wipe it off.
Jan 22, 2013 | Rinnai E75CN Condensing Boiler
If the refrigerator is running without any other problems, then just replace the fan motor. Here is the fan and it is only $36.80. No where near $100.00!
Oct 15, 2012 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a Wall mounted Fujitsu Air Con unit (AOT9LSAC) and will only blow room temp air. The green timer light continualy flashes and the red led opperation indicator flashes 8 times. Can you advise me as...
I have exactly the same problem. Pulled apart the outside unit (condenser) and found lizards have crawled under the circuit boards and been cooked. The circuit boards look all burnt and I suspect this is where the damage is. I have removed the boards but not sure where to get replacements.
Nov 13, 2011 | Fujitsu Heating & Cooling
My stereo is installed outside in my BBQ island. I have a cover for it to keep it dry. We recently had a huge rain storm and water got inside the cover. Although there is still power running to the...
If water did get into the cover of it the circuit board may have got condensation inside and on it. There is no way to tell if there is condensation is to look inside the amp and inspect the circuit board. Also I would not run power through it because if there is condensation on the circuit board you will fry the components.
Dec 23, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Condenser board gives me 6 flashes says vc ch tripped
When you can your cover off your control panel look on panel for Troubleshooting lights. Sometimes the board itself has the codes. Low pressure or high pressue or maybe sensor failure. Different board diferent codes.
May 09, 2009 | Heating & Cooling
Bryant a/c heat pump "model 540bj024"
Check if you have 24volt out of the board if not replace it.
Feb 22, 2009 | Bryant 463AAC008BA Air Conditioner
Cold tech commercial reach-in freezer
sounds like an issue witrh the microprocessor to me as well, although you tried bypassing it it still didnt work its quite possible that the fan aand compressor are runnig on different voltagfe the 110v , new energy effient compressors are starting to run w/ 220, an inverter built into the circuit board could be steppin up power,
Apr 08, 2008 | Freezers
Clicking from Condenser
I would have to say it's your fan going out, also if the units aren't fixed the the DD should come out and fix it for free since it wasn't done the first time. I would take a look at it but I don't know where in florida you are. I'm in highlands county. If your close enough I could come take a look. If there's clicking coming from your condenser then it's one of two things, the compressor or the fan. hopefully the fan. let me know.
Sep 29, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
426 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
