Question about Samsung SyncMaster 740N 17" LCD Monitor
N0 or Very little backlight on Samsung SyncMaster740 17" Monitor
When you press power botton on monitor, power light comes on and remain on but the backlight go's off after two seconds
  • Nerijus Mazuolis May 11, 2010
    its the microchips NT68F63L problem on vga board or bad capacitors. you need to open
    monitor to solve the problem. there are more than 3 ways how to repair.
    Can you open the monitor ??
    or
    if you want there is manual how to repair samsung monitors with this
    problem you can find on ebay: Repair manual Samsung monitor 710n, 913v,
    510n and more, Item number: 220389041052.
    it shows step by step reparation process.
    Problem Solver:
  • 17 Answers
Back light is going bad. if you see a pinkish hue on the" checking signal" box on screen when it comes on. Should be white.
Posted on Jul 30, 2010
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
My Dell 1905fp Ultrasharp was coming on intermittently for a little bit and then it would not power up at all.
You said your monitor will be on for little bit and then would not power up anymore... there are two possible reasons why this problem occur..
1. You need to check if the high voltage ballast transformer of your backlight inverter is about to be burned... the transformer is overheating..that's why you experience the monitor working for a couple of minutes and then it will shut off until the transformer cool down again and then it will be ready to work again...
2. You need to check the power supply section for possible loose connections and blown capacitors.. the ballast transformer has direct effect on power supply section.. when there is overheating transformer,,, the supply current from the power supply section becomes unstable.. and will not be able to supply the remaining good working ballast transformer.
In case you do not know, the ballast transformer generates high voltage for the backlight inverter to work..The backlight inverter is the light source that is responsible for the image display of your screen...If the ballast transformer is not working or if the backlight is busted then the only thing that you will see in your screen is black....
Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....
Much appreciated if you rate this help...thanks...
May 24, 2010 | Dell UltraSharp 1905FP LCD Monitor
Samsung syncmaster 203b problem
This is a typical symptom of a failure of the capacitors on the power supply board. When the filter capacitors go bad the power supply can not start up correctly so you get flickering or even no display. You can repair this unit by replacing the bad capacitors and a fuse on the power supply. This is an easy repair, it just requires a little soldering. Here is a lin to additional information on which capacitors need to be replace and also here is a picture of the power supply board with the capacitors and fuse circled.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
Apr 04, 2010 | Samsung SyncMaster 203B LCD Monitor
My hp vs19e monitor has dark screen and blinking power button.
Could be the power module or the backlights (more likely backlights if the "luminance" varies)- $156 sounds a little high but not insane, but you realize cost of replacement is lower, do you not?
Aug 13, 2009 | HP vs15 15"LCD Flat Panel Monitor
I have just gotten the Samsung syncMasterP2570 monitor and the on button is just flashing and monitor does not come on. When I take out the Dvi or the hdmi I get the auto light flicking. I know that is to...
Your samsung monitor has a bad power mosfet connected to your backlight driver. Or if not you have a bad backlight or bad capacitor's. This problem is normal to samsung syncmaster monitor.
Jul 24, 2009 | Samsung Computers & Internet
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
I have Acer Aspire E560 Disktop, all of a sudden it stopped bootingbut each time i press the power botton it comes on and the fan blowsfor a short while and stops. it doesn't display anything on the...
your monitor power light is on? lcd?
maybe a backlight issue?
have you tried a different monitor?
if the pc is booting up it may be the monitor, if your pc is not, yes it could well be the processor or the motherboard itself.
Feb 25, 2009 | Acer Aspire™ T180 PC Desktop
Vl1918 backlight replacement
this is not a driver issue. There is a hardware problem. You will have to replace the lights, or purchase a new monitor.
Please rate me.
Thanks and good luck, let me know how it turns out.
Feb 02, 2009 | Princeton Digital VL1918 Monitor
Princeton 19" lcd vl1918 BACKLIGHT replacement
On the bottom of your monitor or on the right side is a set of buttons one is for brightness and contrast try to reset the brightness and then contrast. If this does not work you may need a new monitor.
Jan 25, 2009 | Princeton Digital VL1918 Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
263 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
