Question about Acer Aspire 5315 Notebook
  • 289 Answers
Hi..check out the following image to insert
the RAM in your laptop.
try it out..
thank u..
rate me..
Posted on Feb 22, 2009
Is it hard to add more RAM-- Id like to try it myself to save money
It's easy - press the "Easy Button" from Staples. They'll determine which ones you need.
Dec 31, 2010 | Acer Aspire E360 PC Desktop
Add more ram
To add ram - look on the back of the lap top. You will see some screws that are holding down a little door. There may be two of these. Remove the screws on the ram cover and remove ram cover
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ram slots are stacked. you have to remove the top one first.
1- press the buttons on the sides of the ram chip, and then it will pop up and towards you.
2- 2- pull this ram upwards and out
3- from there, you can take out the other chip, if there is one, or you can start installing.
4- installing the new ram chips is just as easy
5- line up the slots in the chip, then push it in as far as you can without breaking it.
6- then push it down so that you hear it click on both sides, and doesn't budge.
7- Repeat using the top chip.
This should do it –
I hope it helps- please rate me – thanks
Mar 18, 2010 | Acer Aspire 9500 Notebook
I have an Acer am5100-u5301a. Is there a bios upgrade?
If the specs read that you can operate with 4GB of RAM, then I believe the AMD690g chipset is not the culprit.
The RAM that you're adding may be defective, or incompatible with the existing RAM.
Another possibility could be a bad RAM socket.
I also doubt you would get a black screen due to adding more RAM than the system is capable of handling, it would still start, but would not utilize the additional RAM.
Black screen usually means bad RAM or incompatible RAM or bad socket
Nov 02, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
How to install more ram
Most laptops have a small hatch on the underside, usually held closed by a single screw. Should be a piece of cake adding more RAM, remembering that there is probably only one slot, so your original one meg will have to be taken out before you add new RAM chips.
Sep 20, 2009 | Acer Aspire 4930-6862 Laptop
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
I want to add memory and dont know how to remove battery first
You don't need to remove the main battery to install or remove thr RAM module/s
The RAM module/s will be located behind a panel on the bottom of the laptop on most laptop models.
Jun 28, 2009 | Acer Extensa 4620 Notebook
attach the ram in mother boart slat2
Feb 22, 2009 | Acer Aspire 5315 Notebook
I am trying to add additional ram to an aspire 5315 with vista. when i start up. I cant get it running. What should I do to activate the second RAM slot? I am trying to upgrade to 4G by adding another...
my deskto acer no AC512. after re formating the pc i lost the sound and vdieo, and iam not having the original cd with me
How to re install the same?
Aug 24, 2008 | Acer Computers & Internet
I need Acer g710 Ram
If you need Ram, you need to contact your server manufacturer to find a product number for your server and memory model/size.
You can add up 16GB of RAM DDR2.
Many manufacturers also provide compatible memory like Transcend or Kingmax.
Can i help you with anything else ?
Mar 29, 2008 | Acer Altos G710 Server
Acer Aspire 5315 Notebook Logo
162 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
