Question about Yahoo Messenger
When i double click my yahoo messenger 9 nothing happens... nothing! what happened?! it was just not working then i check my processes in the task manager...its there but i cant get it to work...
  • 981 Answers
Meh, it takes forever to start up, and it's probably firewalled.  What does your firewall software (e.g. Microsoft's) say about it?  Change that, get a more responsive app.
Keep in mind that Yahoo has no business model for these free services, so if you don't feel like being sold out, you might be wary of running their tools.
Posted on Feb 22, 2009
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
How to close yahoo messenger tray?
try right clicking and click close if that doesn't work then open task manager by pressing (ctrl-alt-del) click yahoo messenger and click end task if that doesn't work go through the processes tab find the one that looks most like yahoo messenger and kill the process. if that doesn't work restart your computer.
Mar 19, 2011 | Yahoo Messenger
My IM window does not display...when i right-click on any of my contact and select Instant messaging...nothing happens...also I tried video call and voice call...nothing happens...and also there is no...
dear friend,
may happen that the yahoo messenger you are using is corrupt or some files are missing...try to download it from other site(softonic .com)
hope this will do
enjoy & cheers
Jan 15, 2011 | Yahoo Messenger
I have just installed internet explorer 9 beta and my yahoo msg will not work i uninstalled yahoo msg and now can't install it explorer 9 is stopping me and i can't find the uninstall for explorer 9 help...
Hint number one. Dumb IE9. Chrome is fast and it will work. 1. Press Control Alt Delete same time. 2. Choose task manager settings 3. Click on applications, if it says not responding end it. 4. If 3 doesnt work click on processes and end explorer 9.
Dec 20, 2010 | Yahoo Messenger
Can't sign in
check your user id and password. Check for capital letters. Check also your internet connection. If your account is compromised, go on with the long procedure. click forget password and answer some question.
May 17, 2010 | Yahoo Messenger
Cannot Log into Yahhoo messenger
1. First, ensure that your computer is connected to the Internet.
2. Confirm that your password is not hacked by loging into your yahoo email account with the same user ID that your using to login to the yahoo messenger, by going to http://mail.yahoo.com.
3. If you are able to log into your email account, your ID is safe.
4. Try to kill yahoo messenger on your system using "Task Manager"
5. To open Task Manager, right click on your computer's task bar at the bottom and click on "Task Manager".
6. Next, click on the "Process" tab in Task Manager, select "YahooMessenger.exe" and click on "End Process" button.
7. If you cannot find "YahooMessenger.exe", then select "Ymsgr_tray.exe" and click on "end process".
8. Now start your yahoo messenger again and try to login. You should be able to login succesfully.
9. If your Internet connection is fine and you have followed the above-mentioned process and still cannot login to yahoo messenger, your system's fire wall is probably obstructing yahoo messenger to access internet.
10. Change the necessary settings on your firewall to leverage access to yahoo messenger.
May 15, 2010 | Yahoo Messenger
81003002 yahoo messenger error
Here’s what you need to do in case you encountered Yahoo messenger error 81003002:
  • Double check your Yahoo ID and password. If at several times of sign in attemps but you still get the same error, restart you PC and if you are connected to a modem or router, do the same.
If you are sure that no virus has actually penetrated the system, there is no need to run a system scan.
  • While some blogs advice reinstallation of the software (of the same verision, i.e. v9) and some may even advice removal of v.9 and installation on an older Yahoo messenger version like Yahoo Messenger 8, do not waste your time as I have already done that. The older version of the IM software no longer works.
Again, if you have had error 81003002 while attempting to sign in to Yahoo, open Windows Task Manager (by pressingCLT+ALT+DEL), select Processes and find YahooMessenger.exe and click End Process. Try to do this several times but if it does not work, then try to reinstall the software. Doing this step does not guarantee that you will be able to sign in but its worth the try. The surprising thing is that when it happened to me, I removed Yahoo Messenger v9 on one of the PCs within my nextwork, the next day when my sister checked it out, she was able to sign in. It just simply fixed itself overtime. Huh?! It’s fascinating why did it happen? Could it be that our IP has been blocked by Yahoo for the entire day and restored it afterward? It’s not a virus as I’m 100% sure. It could be a bug though but I’m not certain what caused it so what I did was reinstall the instant messenger again and I was able to sign in to Yahoo messenger finally.
This is what happened and it’s something that I don’t have any technical reason to offer but I suspect that it was really a bug. Have you experienced the same scenario? What did you do?
FYI, if you are in need of using the application but was caught in a situation similar to the one discussed, you can try signing in to these alternative link or sites to get Yahoo! Messenger access.
Mar 28, 2010 | Yahoo Messenger
My messenger doesn't open
Please check the right bottom side with clock ...there will be one gray Yahoo messenger ICON just double click on that or Right click and choose Show Yahoo Messenger...if that is not there press Alt+Ctrl+Del to open Task Manager...check if there is any process running related Yahoo or Named Yahoo....just Choose that and End Process that...
Now try open yahoo messenger again...
If still not works...Uninstall Yahoo messenger....restart PC...Download and Install it again....
I think it will help you..
For further help please be with us.
Thanks for joining Fixya...Good Luck
Nov 24, 2009 | Yahoo Messenger
My Yahoo Messenger wont open?but earlier I still can use it but now when I click the icon nothing is happening.pls advise..
Your process probably just froze.
Press (on your keyboard) Ctrl + Alt + Delete at the same time and the task manager should come up. If you have windows vista then select task manager when given a list of options.
--> Go to the Tab that says "Processes"
--> Look for the name "YahooMessenger.exe" on the left hand side. and click it to highlight it.
--> Click "End Process" on the bottom right hand side.
--> Its going to ask do you want to end process. Just say yes. Or it might hesitate for a minute and say the task is not responding. Simply hit "End"
--> Once you no longer see "YahooMessenger" in the list, double the yahoo messenger icon to bring it back up.
If this still does not work your going to have to unistall and re-install the program.
Mar 27, 2009 | Yahoo Messenger
My instant messenger is not working
uninstall the current version n install a previous version.You can get previuos version of yahoo messenger form filehippo.com
Feb 10, 2009 | Yahoo Messenger
Yahoo Messenger Logo
116 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
