Question about Whirlpool LSB6200KQ Top Load Washer
My maytag washer will fill up with water but not start washing
I own a Maytag lsb6200lq1 top loader. I select the size of load and the water fill but nonthing else happens it won't drain, spin or drain. just fills up. needless I have a washing machine that full of water not going anywhere. If anyone can help please let me know
  • 1 more comment
  • Kel30_99 Mar 18, 2009
    My Whirlpool Gold washer filled up last night, will not agitate or spin. I was able to once get it to drain the soap water, filled it again (silly me) and now it just sits there. Not sure if the unit about 9 years old should be fixed or not??
  • fergy45 Mar 23, 2009
    i have a kenmore elite it will fill up agitate but not drain or spin
    please advise
  • Anonymous Mar 30, 2009
    maytag model number mav1754eww will fill but will not start
  • Whirlpool Master
  • 3,361 Answers
Replace your lid switch.
Posted on Mar 08, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Maytag top loader won't agitate. will fill and spin
Try this:
When the washer should be agitating, try turning your load size switch back and forth a few times. If you are on a medium load, going to a larger load should cause it to begin filling again, going to a smaller size should start the motor for agitate. If this works, your pressure / water level sense switch is okay, but the switch for load size is faulted / or is on its way out. If you went from a medium load, to a higher load, then your pressure switch is faulted as well.
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Maytag PAV2300 Top load washer
check your hose from the side of the tub all the way up to the water selector knob. if its loose or has even a pin sized hole in it, it will cause the maching not to sense it has reached the level selected.
Nov 29, 2007 | Maytag PAV2300 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
1,045 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
