Question about Dell Inspiron 1000 Notebook
Backout problem with the lcd, dell
Hi, my name is zachary and i have the windows xp, dell. Each time i turn my laptop on, the lcd blacks out. Everything works fine, and would work like it would regularly would do when i turn on my laptop. But the lcd turns black, i cant even see a thing on my laptop. I unscrewed some of the cards on the bottem of the laptop and put it back and the lcd still wouldnt turn on. Is their something stuck in the lcd or do i have to fix the blacklight and if i do have to fix the backlight, how?=(, can someone PLEASE HELP ME!!! i need help really bad.
  • RescueTechLA
    RescueTechLA May 11, 2010
    When you say blacks out, does it work at least for a few seconds or does it go super faint?
  • 17 Answers
Hi, it sounds like the backlight inverter is failing. you will need to remove the screen surround to acess it . make sure you remove all power and battery before atempting. its not too difficult a job to attempt. remove any rubber bumpers around the screen to reveal the screws holding the surround in place, remove the screws then you will need to clip out the surround taking care not to damage your screen. when the surround is off this should expose the backlight inverter a small circuit board about 10-15cm long there are wires attached either end its simply a case of removing the wires and replacing the inverter. putting back together is simply a reversal of the dismantling proceedure.
hope this helps
Posted on Feb 22, 2009
I locked my self out of my dell latitude d620 Administrator password
Crack Dell Laptop Password ' Want To Hack Into Dell Notebook Computer / PC?
  • Usually, We may create a user password to protect our Dell laptop. Unfortunately, we often forget the password then can't access the computer. This article will tell you how to crack Dell laptop password.
May 07, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a Dell Latitude D820. It is password
Try pressing control alt delete, which should start your task manager..
Then choose new task
type in explorer
If it pulls up a window, then what you need to do is a system restore..
If it does not pull up a window, then you will need to locate a xp install disk or one of your recovery disks and try a repair install
Oct 30, 2009 | Dell Latitude D820 Notebook
Error loading operating system in dell
You may be right , the harddrive on the system may have gone bad.
You can run a diagnostics on the hardrive,shut down the computer, and then Press the Fn+ power button at the same time , it would initate the diagnostics.
Do post the results back
Thanks
proton
Apr 05, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
CAN'T INSTALL DELL DOCK APPLICATION
Its most likely that you have downloaded a very old version of software with the same name. The dell support website has many listing when you search for Dell Dock. Always use the website below for the latest version of Dell Dock application. http://www.delldock.com/
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 21, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Display andLCD problem
Reboot the sys and go to the bios screen. Change settings back to default and reboot.
Dec 11, 2008 | Dell Inspiron B130 Notebook
Help
Hi
I am afraid Dell did no plan Windows XP for Latitude C600 thus Dell has not made released certified drivers.
Generally, Windows XP SP2 should have most of the drivers built in. Reply if you have device(s) which lack drivers and I will get you the drivers at best effort.
Also, try Windows 2000 drivers. Normally it should work
Latitude C600 Windows 2000 driver list -
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=LAT_PNT_P3C_C600&hidos=WW1&hidlang=en
Mike
Apr 19, 2008 | Dell Latitude C600 Notebook
Dell Inspiron 1000 Notebook Logo
47 people viewed this question
Alun Cox
