Question about Canon PIXMA MP150 All-In-One InkJet Printer
Always prints in color even while printing black and white
Prints in color even while trying to print black and while
  • Steve Nordquist
    Steve Nordquist May 11, 2010
    What printer settings are you using?  If you use native color and tell iti to print B&W only, does it do the same thing anyhow?  (Cite the driver version you're using, of course.)
  • 42 Answers
There are several setting for color printing ... first check the printer settings, then the programe setting, then the dashboard printer settings.
Posted on Feb 22, 2009
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Epson Stylus Pro 4000 is printing green instead of black
Hi mariann346i am having the same problem with my EPSON RX 595 printer.
i can not print in black and white, it always prints in green.
i also notice something els, even after refilling my six cartridges
and only trying to print in black and white, my yellow ink is running out just as fast as my black so i guess they are somehow mixing together. you should check to make sure your yellow isn`t doing the same.
Jul 14, 2009 | Epson Stylus Pro 4000 InkJet Printer
Can't print in black ink.
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
May 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Won't print black and white, looks blue
HP uses a system for black that prints a base ie: Cyan / *blue then overprints it with black...
Sounds like you are either out of black or you have an ink clog?
If so... you need to use a print head cleaner like Magic Inkjet Flush you can get a kit on Ebay.
Good Luck!
Apr 09, 2008 | HP OfficeJet r40 InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Only prints in black and white
before you print go to the print properties or preferences, in there see if you find a setting that says black/white or color. select color then print.
you may or may not have this option. the older HP ink-jets defaulted to Black/white and you had to manualy select color from the current document you where printing.
Dec 05, 2007 | HP OfficeJet 6110xi All-In-One Thermal...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
115 people viewed this question
old marine
old marine
