Question about HP Computers & Internet
Wireing diagram I have a hp xt963 some one puuled all wires of the motherboard is there a diagram some place i can find to help me plug all wires back please
    President:
  • 2,692 Answers
Download manual . ,Users guide. Data sheet. for the HP website. Your model Link below.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=62764〈=en&
Posted on Feb 22, 2009
PSU and motherboard wiring
The wiring from the PSU to the motherboard is usually quite straightforward.
The plugs are multiway and often all in one (although there are exceptions)
Make a sketch of where the plugs go to on the motherboard, and then take the PSU to your local PC emporium - they should be able to recommend a suitable replacement.
Feb 05, 2014 | HP Computers & Internet
What is the 4 wire square chuck on the motherboard ?
it is a power plug that goes hear the cpu socket area
Feb 08, 2013 | HP Compaq Motherboard
I need a picture of what the insides of the tower looks like a plug fell out
Tell me what is the wire color ? it should be nothing other than the LED light / reset / power button.. Just confirm me if all the front panel buttons are working ?
this is the motherboard picture but it wont help unless you find what is not working in ur pc - https://www.blueraven.com/BlueRavenResource/ItemimagesLegacy/Z3807-0.jpg
Jan 28, 2013 | Acer Aspire T180-EA350M (AST180EA350M) PC...
HP Compaq nc6220: I need a diagram of motherboard to fix cmos wire connector. The power module on the mobo came loose while plugging in the cmos wire.
Top View/Bottom View,
http://www.ebay.com/itm/382909-001-New-HP-NC6220-Laptop-Motherboard-/170926166342?pt=Motherboards&hash=item27cbfe5146
Hover your mouse cursor in the middle of the two views. Use the Zoom feature to look at the connector, and the direction it is facing.
-> Only faces one way <- This lines up the polarity of the wires.
Using which one goes where on the motherboard's connector, suggest using short splices of wire, soldered to the existing wire 'nubs' coming out of the motherboard.
(Or existing solder joints, that went to the motherboard connector for the RTC Battery)
(Use a low wattage soldering iron, and a No.2 chisel tip. Well tinned, and have a damp sponge nearby to occasionally clean it.. Do Not suggest using as soldering gun.
Area around wire 'nubs, and wire nubs, needs to be cleaned properly. If not the tinning you need to do to the tip of those wires, won't take.
(Tinning - Thin coat of solder)
Clean with an old toothbrush, and Isopropyl Alcohol.
(Rubbing alcohol. 91 percent is best, but 70 percent will do)
CAUTION!!
Isopropyl alcohol is EXTREMELY FLAMMABLE!
Use in a Well ventilated area with NO sparks or flames present.
Tips of those wires needs to be tinned, and the both ends of the short jumper wires you're going to use. Heat shrink tubing needs to be used on the wires, before soldering any wires together.
The combination RTC battery harness plug, and the motherboard connector will have to be checked out for fit, when the case is put back together.
That is to say; Look to make sure there is space for this moved combo. Otherwise the wires will become pinched, when the case is put back together. laptop won't go back together, and wires may be damaged.
Motherboard connector for the RTC battery harness cable.
The reference already implies to those who know, that the RTC battery harness has a plug on the end, and the above is what it plugs into.
(RTC Battery = Real Time Clock Battery. The reference used in place of CMOS battery now )
HP Support > HP Compaq NC6220 Notebook PC > Manuals > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=447371
Service and maintenance information >
HP Compaq nc6220 and nc6230 Notebook PC - Maintenance and Service Guide [ 15 Mar 2006 / PDF / 4.16 ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2012 | Dell Computers & Internet
Where is the ethernet plug location on a HP Pavilion xt963 PC
If you are looking for the one on your PC, it looks like a huge Phone plug at the back of the machine...if not, please clarify...
Jan 31, 2009 | Computers & Internet
Motherboard wiring diagram
i need a wiring diagram of my mother board...usb power etc etc. any idea where i wud find this
regards Des
Feb 07, 2008 | Intel Motherboard
Ms-6119 front on/off. reset wires disconected from motherboard
http://stason.org/TULARC/pc/motherboards/M/MICRO-STAR-INTERNATIONAL-CO-LTD-Pentium-II-MS-6119.html
If the leds dont light up rotate the plug 180 degrees.
The above site shows you where to place the plugs.
Nov 28, 2007 | Computers & Internet
Computers & Internet Logo
280 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
