Question about ASUS K8N-DL Motherboard
Lock-up before POST
I've had two of these boards & both have suffered a freeze/lock up before POST rendering them useless.
Asus refuse to acknowledge there's a problem & both are out of warranty anyway (one was purchased abroad & the other off Ebay).
Both boards get to the Asus splash screen then freeze before it finishes POST. The code in the bottom corner always says 5B when it freezes if that's any help.
  • chaz_c Jun 02, 2009
  • 2351 Answers
SOURCE: asus m2n-e sli locks up at bios post splash screen
Sounds like a bios issue. Try resetting the bios, pg. 2-19 in user manual. After clearing the bios jumper, make sure you set it back to pins 1 & 2. If you still can not get into the bios main menu than head to Asus, click this link.
Since this is a new board & all Asus boards are warranted for three years I suggest you talk with an Asus tech. If you flash you're bios during the warranty period you may void the warranty. You can call Asus M-F, EST 8:00AM-5: PM.
1-812-282-2787. Not sure you have this number in you're manual. Chances are Asus will send you a new bios. Or you can buy a new bios for $5.00 not including S/H. From Asus online store. Click on this link.
If I can be of more service, just post back & let me know how thing go.
Posted on Apr 27, 2008
  • 4 Answers
SOURCE: no post
Have you:
Made sure everything is connected properly?
Reseat (remove and put back in) the components (Memory, Video card, HDD, cables)?
Run with only the essentials (CPU, Motherboard, video, RAM)?
Will the PC even power up?
Posted on Jun 29, 2008
SOURCE: game/midi port
I tried to use a Logitech Wingman Joystick...and windows would not recognize it even after loading the I assumed the gameport would have to be enabled on my motherboard
Posted on Sep 06, 2008
  • 827 Answers
SOURCE: Asus p5e3 freezes at POST.
Hi David,
Maybe you could buy a new CMOS battery and replace the old one..
Might be worth a try..
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
  • 334 Answers
SOURCE: I have always been able to at least get to the
Hey there, I would try clearing the CMOS. Pull the power cable off then find the clear CMOS pins and jump them out for a few seconds. You may have to reconfigure your bios but hopefully it will work for you. If not and you get no error beeps meaning its not post and you need to replace the board. Good luck.
Posted on Jun 11, 2009
ASUS X501A Locked (not bios, HDD or Windows)
Can you tell more detail about your situation? As you mention that you seem cannot be able to switch on your laptop. Or you can switch it on and in which status?
Dec 06, 2013 | Asus Systems Asus X501A Notebook
Schlage cobra default code
There is no "factory default code". If there was such a thing, you could bet that any good thief would have it-rendering your lock useless as a security device.
Try for further information.
Feb 13, 2012 | Schlage COBRA by Keyless Lock
Pc comes on but screen wont come on
There are a few possibilities as to what's causing this problem.
First, there may be a problem with the screen's backlight, either with the bulb itself or with the power inversion board. This can be repaired fairly easily with a little time and care.
Second, and more catastrophic, there may be a problem with the graphics processing unit (GPU), which would render the laptop totally useless.
Third, if some other component came loose (RAM, wireless card, hard drive) and is no longer connected properly, most systems will refuse to boot. This is obviously the easiest problem to fix.
The easiest way to test whether your laptop is actually still running or if it's burnt out is to make sure it's completely shut down, connect an external monitor, and power up. If you see the computer's start-up splash screen or BIOS diagnostics, then the problem lies with the screen itself.
If you don't see anything on screen, don't hear any beeps or sounds from the computer, or can't toggle CAPS LOCK or NUM LOCK, then it's more likely that there's a hardware problem. If you've checked all the connections for the above mentioned components, then some component may have burnt out and would need replacement. In that case, your best bet would be to physically take the laptop to a repair center, such as Best Buy's Geek Squad, Staples' Easy Tech, or any of your local computer repair centers, and have them run detailed diagnostics on it. If your laptop is still under a service plan, send it in to HP and have them fix or replace it.
Jun 09, 2011 | Compaq Presario CQ56-115DX Laptop
I want to upgrade my navigation system in my ls430 2001
U must contact the support web site of the manufacturers of the GPS, any attempt to use non approved software will lock up the GPS programming and render it useless.
Sep 30, 2010 | GPS
I have a Asus P5VD2-VM SE and when i boot my pc this show me a message Chasis intruded System Halted someone can help to solve this problem
You will need to go into your system BIOS and disable the Chassis Intrusion Sensor. BIOS is accessed by pressing the "del" key during the initial POST screen (or when giant Asus logo is on the screen) .
Look through there and located and disable the chassis intrusion sensor. If you can't find it, reference your manual for the board. If you don't have one, one can be downloaded in PDF format from the Asus website.
Be careful when in the BIOS, changing anything to an incorrect value could render your system useless! Don't play with anything, unless you explicitly know what you are doing, and what the setting does...
Be sure to "Save and Exit" in order foe the changes to stick.
Dec 18, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I have forgot my nokia 5320 phone lock code
If your handset is asking you for a PIN, you will have a few attempts to get it right, before it locks up and asks you for a PUK code.
If your handset is asking for a PUK code, Call your telecommunications provider. They will be able to issue you with one (don't try too many times, as you will render the phone inoperable)
If you have used up all of your attempts to get in at the PUK code stage, you will need to ask your telecommuncations provider, or the handset manafacturer for assistance. They will probably ask for proof of purchase and may charge a fee. If a handset has gotten to this point, the phone will probably be rendered useless.
Also, if you have set a code, and forgotten it, follow the next steps:  Be careful not to render the phone useless by trying too many times. You could try the defaults:
  • 1234
  • 12345
  • 0000
  • 00000
Failing that, try the code generator here:
May 21, 2009 | Nokia 5320 XpressMusic Cellular Phone
Display breaks , scrambles and freezes!
Gee, perhaps a virus scan or spyware scan is in order.
Until this post is removed, DO NOT OPEN the attachment above. Common exploit.
Mar 21, 2009 | ASUS Computers & Internet
Asus Motherboard not booting
Once you,ve Flashed The Bios unsucessfully the board is dead.
Theres Nothing You Can Do, Unless The Bios-Chip Is In A Socket On The Motherboard, Which Is Removable.
You Can Then Send It To A company to have the bios re-flashed.
The Bios Is The Motherboards Memory. Instructing it What to Do on Boot-up, what it,s capabilitys are, what to do, what to look for
For when they,re connected to it, what how to configure items. et,c et,c. By re-flashing The Bios.
You,ve rendered The Board Useless
The Valuable Lesson Here Is. If it,s Not Broken Don,t Try to Fix It. Look On The Internet For Bios/eeprom Reprogramming.
Mike @ Compurepair.
Posted @ 09.21 AM ( G.M.T )
Mar 03, 2008 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Oven remains locked after self cleaning
I ended up paying an independent appliance repair man $149.00 to fix my problem. However the "fix" also includes the fact that I can never lock the oven again.
Nov 22, 2007 | Viking 27" Professional Select Built-in...
ASUS K8N-DL Motherboard Logo
107 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
