Question about Pentax Optio E30 Digital Camera
SD memory prohibits functioning of Pentax E30
I have a Pentax Optio E30, when I install a sd card the unit powers on with PENTAX OPTIO screen showing but will not function. When I remove the SD card (3 different SD's have been tried) the camera will function properly. The SD cards are not new but do work in my Nikon camera. Do I need a new SD unformatted? I deleted all pictures from the SD's but still no luck.
Please advise if you know what to do. Thanks
  • 423 Answers
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Posted on Feb 22, 2009
SDHC 16 GB memory card compatible with Pentax Optio 450
No, you cannot use SDHC cards with the 450. You can only use MMC and SD cards, 2GB and smaller.
Aug 01, 2012 | Pentax Optio 450 Digital Camera
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
I have purchased a 4GB SD-HC memory caard for my pentax optio s6. when istalled the card, the screen was turned on ok, but could not perform any function. Few minutes later a "memory card error"...
The Optio S6 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to use SD cards, 2GB and smaller.
Jan 13, 2011 | Cameras
The memory card on my pentax optio camera is locked. a yellow key appears. i found the display showing the key but cannot find the function to unlock it
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 25, 2010 | Pentax Optio E30 Digital Camera
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
Camera won't read new SD card
The sd card is to big go for a 2gb ted10
Apr 18, 2009 | Pentax Optio 550 Digital Camera
Pentax digital camera optio s memory card locked
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 25, 2009 | Pentax Optio E30 Digital Camera
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Dec 10, 2008 | Pentax Optio E10 Digital Camera
Pentax Optio E30 Digital Camera Logo
162 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
