Question about Epson STYLUS CX3900 All-In-One InkJet Printer
My epson Stylus cx 3900 won't feed paper anymore. only the right edge (as you ,look at it is fed through. The wheels are turning and it is making all the normal sounds. The printer head even starts working like it is printing It thinks the paper is there???
  • Felinna
    Felinna May 11, 2010
    you should probably check the wheels on both sides are grabbing the paper. you can do that by taking a narrower sheet and placing it on the problematic syde. if it doesn't pull, check if the feeder wheels are rotating. in either way, you probably need to get the printer repaired.
  • 66 Answers
Your might need new roller pads...depending how long you have the printer or how much it...They are maintenance kits.
Posted on Mar 12, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Feeding problem
give one paper and check if it accepts correctly
Oct 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    How to load ink cartridge into cx3900 printer
    Here is a link to a good website to provide you a downloadable pdf file which is a graphical chart detailing how to Load paper and replace the ink cartridges for the Epson Stylus CX3900 series.
    Epson Stylus CX 3900 All-In-One Inkjet Basic Start up Chart
    (Includes instructions for replacing Ink Cartridges)
    Hope this helps!
    -Mactechtrainer
    Jan 26, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
    I have a epson printer stylus cx5400 that says error.
    Possible hardware failure.
    Please turn the printer off. Disconnect it from your computer. Check if there are any obstructions blocking the way of the printhead or the paper feed area. Make sure that the cartridge cover is closed properly. Turn the printer on.
    If your unit is not under warranty anymore, please log on to epson.com to find an epson certified servicer near to your area.
    Apr 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
    I NEED MANUAL FOR REPAIR EPSON STYLUS CX-3900
    http://tech.epson.com.au/downloads/message.asp?platform=winxp&techtips=techtips&EmailAdd=&MetricIDReturned=2694589&submit=Search+%3E%3E&sCategory=Multi_Functional&id=styluscx3900
    Copy and paste link in browser then download the user manual.
    Dec 16, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
    Paper twists when feeding
    there is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
    Nov 04, 2008 | Epson Stylus Photo 950 InkJet Printer
    My printer, makes a grinding noise, when the paper is feeding through when printinig?
    Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
    Mar 22, 2008 | Epson Stylus Photo R300 InkJet Printer
    Epson STYLUS CX3900 All-In-One InkJet Printer Logo
    370 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
