Question about Proview XL370B (Black) 17 in. Flat Panel LCD Monitor
I have a 2004 XL370b model Xerox monitor, just for home use. The audio cable does not seem to be working, I would like to know if it is replaceable. The screen functions fine, I'm very happy with it, I just have no sound.
Xerox lcd modle number 900p Power supply fault plz send pics of supply 1 ic burst i never know number
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ... Ac Dc Adapter Charger for Xerox Model 900 ... > ... > Monitors, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
Nov 23, 2015 | Xerox Computers & Internet
XEROX Monitor Product No : XM3-19W Model No: 900W Power: AC 100-240V 50/60Hz 1.2A Problem : " RGB Analog " When Starting the monitor afte 3 second display and then Black screen.
Common failures in LCD monitors are due to bad caps as hown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Capacitors kit: he can make you a set of caps for you.
Oct 06, 2010 | Xerox XG-91D 19" LCD Monitor
Vga lead will not fit tower
Try turning it around. If it still doesn't fit, you may need a DVI to VGA adapter.
Aug 05, 2009 | Xerox Computers & Internet
Broken powerboard for Xerox XM3-19W monitor
Well you might be able to find one in a scrap monitor on an auction site, or put in the model number on google. Im always after parts for monitors and it gets annoying when you cannot find any lol.
Mar 30, 2009 | Computers & Internet
Xerox 17 XL765 LCD monitor Wavy lines but pitcure is good
i had this same prob. For me it wasn't the monitor but the video card and or mobo. I tried monitors on other comps adn worked just fine. Tried comp on 4 monitors and same prob. bought new mobo and problem solved. New prob fixing mobo and or video card
Oct 27, 2007 | Gateway FPD2275W LCD Monitor
19" Xerox flat panel monitor
always try with another monitor,before do nothing else. this reveal if the problem is the monitor. could be a cable problem( cutted inside),could be a backlight problem (it have a flourescent tube and a inverter that makes it "shine" ,or a supply problem what means it don't even work.these tree case are for the repairman.
Jul 09, 2007 | Xerox XG-91D 19" LCD Monitor
Faulty monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
May 11, 2007 | Proview XL370B (Black) 17 in. Flat Panel...
Proview XL370B (Black) 17 in. Flat Panel LCD Monitor Logo
126 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
