My IBM note book not go windows desktop (Automatically log off)
My IBM laptop computer Not go dekstop
(Automatically log off it)
  • Anonymous Apr 21, 2009
    It logs off immediatey after logging on
  • John Miller Jr May 11, 2010
    More detail is required...what exactly happens? What are you doing when it happens?
I need remove log on password from my IBM desktop
Click Start, Run and type CONTROL USERPASSWORDS2, and click Ok. Select the user account from the list (the account to which you want to automatically logon). Uncheck Users must enter a user name and password to use this computer option, and click Ok. Type the user account password and complete the process.
Feb 16, 2011 | IBM Netvista Intel Pentium 4 2.4GHz /...
How to change my wallpaper ?
Windows 7 --> At dekstop front page, Right click >Personalize > Click Dekstop Background > Choose pivture > Save
Windows XP --> At dekstop front page, Right click > Properties > Dekstop Wallpaper > Browse your picture file > OK
or just open Windows Explorer > Open Folder where you save the picture file > Click file > Right Click > Set as Dekstop background > DONE
Hope this help and if this helpful RATE please.
Feb 03, 2011 | Lenovo IdeaPad Y530 Notebook
I cant install windows xp in my ibm m51 8141 dekstop when i boot system to cd rom then after few minits the system show the error "windows ini file cant loaded" i have 3 windows cds but i try the...
You may have to Reformat your hard drive first. The current hard rive may have a bad operating system on it or one that is newer than XP. In some cases, when a computer has a more current operating system installed, it will not allow an older operating system to write over it. That is why I said, reformat the hard drive. Remember, hardware drivers are written for Windows 10 now, so old drivers may not be functional any longer.
Jan 14, 2018 | IBM ThinkCentre M51 PC Desktop
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
My computer does not go to sleep mode
Start > Put computer to sleep
This should work.
Aug 09, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM thinkpad T43 shutdowns abruptly
plz try with a new power supply unit
Mar 16, 2009 | IBM Computers & Internet
Put new hard drive in ibm 570
you need to install the windows operating system to the new hard drive and transfer your files ...
if you still have the CD installer that comes with it when you bought the computer..use the CD with label operating system..then after you install the windows..use the cd with label drivers and application
Mar 15, 2009 | IBM Computers & Internet
IBM T60 can not connect to projector. I have some
Most notebooks have a keystroke that enables the external video port for presentations.
According to the manual for the T60, your Fn +F7 key combination does the following:
"Apply a presentation scheme directly, with no need to start Presentation Director. To disable this function and use the Fn+F7 key combination for switching a display output location, start Presentation Director, and change the settings."
"Switch a display output location
v External monitor (CRT display)
v Computer display and external monitor (LCD + CRT display)
v Computer display (LCD)"
"Notes:
1. This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
2. This function does not work while a DVD movie or a video clip is playing."
"To enable this function, do as follows when you log on to Windows 2000 or Windows XP:
Note: Multiple users can log on to a single operating system by using different user IDs. Each user needs to do the following:
1. Start Windows 2000 or Windows XP, and log on to the system.
2. Start Presentation Director, and change the Fn+F7 settings."
If you would like to see the entire manual, click the link below.
http://technology.shu.edu/faq/page/t60+manual!OpenDocument
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 15, 2009 | IBM ThinkPad T60 Notebook
Need print server advice
see if you can connect printer to the router, then it will appear as a network location.
Mar 24, 2017 | Computers & Internet
Xp sp2
hi,
Try this,
Right click on my computer then go into the properties, on top theirs a tab called advanced, click on it. under Advanced tab their should be 3 options, 1 should called start Start up and recovery, click on its setting, then uncheck the box called Automatically restart. click OK, OK. restart the computer this should do the job.
hope this little info helps.
TY
Dec 20, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
