Question about Hamilton Beach Water Cooler with Storage Cabinet
No hot or cold water will come out of the dispenser
I have tried for 6 MONTHS to get someone at Hamilton Beach to help me with this issue but customer service seems to be no existent.
Water barely trickles out of the dispenser or nothing comes out at all. We rely heavily on this for drinking water. PLEASE, PLEASE, PLEASE contact me regarding this issue.
E-mail me or call (316) 644-9212 and leave a message.
  • 150 Answers
You may need to clean the dispenser unit thoroughly.Try vinegar and a long q-tip.
Posted on Feb 27, 2009
Hamilton Beach 87330 hot water problem.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
Feb 23, 2010 | Hamilton Beach Water Cooler with Storage...
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Why is hot dispensing cold water
try to check the heat filament or thermostat heater, maybe it is busted that why it cannot dispense hot water, there water source is came only to one tab and it interconnected inside
Nov 04, 2009 | Hamilton Beach Water Cooler with Storage...
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
No Cold Water
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing.
May 27, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
388 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
